Old 07-03-2016, 01:24 PM
Dino Don's Avatar
Dino Don Dino Don is offline
Boat: mastercraft 190 1987 351 Indmar
Thermostat issues
what is the difference between a marine thermostat and automotive thermostat?? With same heat range??
Old 07-03-2016, 01:27 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
You need to be more specific. Some of them, like he LT-1 for example, have a hole drilled in them for a small amount of constant bypass. Literally it is a predetermined hole size from the engine builder and they drill it with a drill bit. I bought mine from skidim and had to de-burr it before install.
1996 Prostar 205 LT-1
Old 07-03-2016, 11:21 PM
Dino Don's Avatar
Mine is a 1987 ProStar 351 Ford engine. Had issues over the weekend and used a automotive style 160 stat temp seemed to run 172-ish. would cycle but didn't know if it would be a problem long term??
Old 07-05-2016, 10:42 AM
slalomjunkie slalomjunkie is offline
Boat: NA
Stick with the specific thermostat for your boat, there is a difference.
Old 07-05-2016, 01:13 PM
most marine t-stats drilled to allow bypass of some water when closed.
Old 07-06-2016, 08:15 PM
Deb Deb is offline
Boat: PS 190 35th Anniversary
You should be running a 140 in there. I have them with gaskets from Indmar if you need~~
[email protected]
