Old 12-10-2004, 10:16 PM
sully's Avatar
sully sully is offline
Boat: 09 214 Prostar
Unhappy Older style Platforms
Just thought I would share some pictures of what I discoverd when I took my swim plateform apart.
This is what I discovered in between the parts that are screwed together. I think discovered it in time .... and all the black comes of with 100 grit sand paper. My plan is to varnish the plateform with Sikkens cetrol. Hopefully this will prevent this rottening in the future.
Sully
09 214 Prostar with MCX
Old 12-10-2004, 10:56 PM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is online now
Boat: 1996 FlightCraft
It doesn't look like the wood is rotting, just some discoloration from the water being trapped between the layers.
I wonder if you might be better off using teak oil for the refinishing of the deck. I've seen the Sikens used on cedar siding and decking. After a while it can start to peel off and it needs to be stripped and reapplied on a pretty regular basis.
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
Old 12-11-2004, 08:50 AM
Leroy
Posts: n/a
Sully; This cracks me up! Now what would have you taking apart your teak deck? Thinking I've missed some maintenance item. Below from the web.
Teak is one of the most valuable timbers, "the king under the timbers", in ancient times considered as "a royal timber". Teak is world wide recognized for its durability and stability, The timber is immense stable, has a high oil content that works as "built-in" natural water repellent and is therefore virtually immune to rotting, fungi and harsh chemicals. Teak is one of the few timbers that can withstand the heat of the desert and will not readily catch fire.
Untreated teak can be left in the open for more than 30 years whilst becoming an attractive soft silver color. Teak is one of the timbers not susceptible to termite (white ants) attacks.
Old 12-11-2004, 11:40 AM
dmac's Avatar
dmac dmac is offline
Boat: 2004 MariStar, Predator Engine
Teak 101 I should say.
Thanks Professor, learned some things. I too am curious on the reason for disassembly.
24 hours in a day, 24 beers in a case. Coincidence? I think not.
Old 12-11-2004, 01:11 PM
Dean Witmer Dean Witmer is offline
Boat: 1968 Century Resorter HO Ford 352 bored and stroked
cetol on platforms
I have used cetol on several platforms and have never had any peeling problems. One caution - Cetol is a glossy surface and can be slippery so be careful not to put on to much. I have it on the platform of my fishing boat and it haas lasted five years with no peeling and looks like new.
Dean '68 Century Resorter HO ford 352 bored and stroked
Old 12-11-2004, 02:17 PM
sully's Avatar
Reason for dissasembly
Well I decided to take my swim platform apart because when I was sanding it and prepping it I noticed the mold (I would agree it is mold and not rotting) in between the slats, and decided I wanted to remove the mold from there also. Well on thing led to another and I kept finding this mold ... next thing I know my swim platform is almost completely apart. I think this will actually work out better. I can get the varnish in between all the parts creating a better finish and less chance of peeling.
Old 12-11-2004, 08:34 AM
H20skeefreek's Avatar
H20skeefreek H20skeefreek is offline
Boat: '85 Stars and Stripes
Sully
Even as a person who sells Cetol, I would highly recommend that you do not varnish your platform with Cetol. As Laural Lake said, it will eventually peel and flake off, and requires much maint. I would highy recommend oiling. If you insist on varnish, you must properly seal the teak with a teak wood sealer before varnishing. Teak is a very oily wood, and will cause the varnish to peel much earlier than on other woods such as cedar.
also, cetol has a bit of an orange tint to it that I don't think you will like.
and the black you see is actually some sort of growth. mold/mildew/algea/funk. teak doesn't rot unless it is wet ALL the time.
ITCHIN' TO SKI, LET'S GO!!
Former Boat: 1985 MasterCraft Skier, Stars and Stripes
351W with PowerSlot and Perfect Pass
Click here if you need prayer, or wish to pray for those who do.
