Old 10-24-2015, 11:35 PM
kyfooter's Avatar
kyfooter kyfooter is offline
Boat: 2013 197 WTT / 1992 Barefoot Sanger
2013 Ilmor heater hose connections
If you have a stock heater in your 2013 MC, would you mind snapping a few shots of your heater hose to engine connections? The 2013 5.7 L Ilmor has a 1" "sub manifold" under the main engine manifolds. Out of each side, on the bottom, is a hose which runs up toward the thermostat. Curious to know if the stock heaters are spliced into the passenger side hose, or if a "T" connector is used and the heater hoses run to both sides of the engine.
Thanks.
Old 10-25-2015, 01:34 PM
kyfooter's Avatar
or is it this hose?
Old 10-26-2015, 05:27 PM
Cyoder1 Cyoder1 is offline
Boat: 2012 X25
I had a heck of a time finding my heater hoses. I have this plastic fitting that tees off. When I removed it and blew in the other suspected hose off the engine my assistant could hear bubbling at the heater. So, I figured that had to be it - right!? Anyway, I blew through it until no water came out and it took about 1/2 gallon of AF before it came out the other hose. Let you know after winter if I was right. Anyway, here is a pic of mine. I would go with the hose from second post.
Old 05-08-2016, 10:29 AM
kyfooter's Avatar
Bump to see if anyone can take photos of their factory heater hookup to the engine. Looking to see exactly where the two heater hoses hook to the engine.
Thanks.
Old 05-10-2016, 09:19 AM
kyfooter's Avatar
...Nothing? Anyone else have a heater in their boat with an Ilmor engine? Anyone???
Old 05-10-2016, 09:29 AM
Can you get a pic of the that plastic tee with the other end in it. If the hose is clear I'm pretty sure it runs to your prop shaft and is used to cool the prop shaft seal.
Tim
Old 05-10-2016, 12:44 PM
kyfooter's Avatar
Agreed...and if that is indeed a heater hose of the "T", then where does the other heater hose attach?
On my 2003 with the Indmar engine, one hose hooked directly into the engine next to the thermostat, and the other hose hooked to the passenger side of the block, under the manifold. MC used a hose bib on the engine.
Ilmor doesn't have as obvious of a hookup...at least not obvious to me.
Old 05-10-2016, 09:27 PM
Markl66's Avatar
Markl66 Markl66 is offline
Boat: Mastercraft X14V 2012
I have a 2012 Ilmore with a heater. I also struggled to figure out how the lines run. Since we brought the boat out of storage this spring the heater hasn't been producing much heat. I thought the problem might have been flow to the heat exchanger. Any help would be appreciated.
Old 05-10-2016, 09:42 PM
kyfooter's Avatar
Maybe we shouldn't be looking at the first few years of the Ilmor engine, but perhaps 2014 and 2015 to model after?
Old 05-10-2016, 11:36 PM
bcd bcd is offline
Boat: 2014 X-2
I had a heater in my 2012. It didn't work well, and they installed a kit to improve performance. They moved the hot water supply to a hotter point on the engine and moved the return line to another spot that was supposed to increase flow through the heater core. Here are some pictures of where the original and new locations were. Even with the changes, it worked better, but still wasn't that hot. I didn't get the heater on my 2014 because of that. I took the pictures in case I put an aftermarket one in someday. I don't know if these changes are where the production locations are at now or not. If you are looking for the heater lines, they are the only two 1 inch soft rubber hoses running up the middle of the boat past the transmission. You can find them through the rear seat access point.
