Old 08-06-2017, 10:45 PM
kyfooter's Avatar
kyfooter kyfooter is offline
Boat: 2013 197 WTT / 1992 Barefoot Sanger
2013 - steering cable bad already?
I have a 2013 WTT with 180 hours. Steering started to get stiff last week so I greased the rudder, and the steering cable in the back of the boat.
Skied today and it's still stiff. Before anyone asks, when I had the cable disconnected from the rudder, the rudder turned very easily.
So...is my cable bad already? Any issues with 2013 cables going bad prematurely? I would understand if it was 7-8 years old, but barely 4 years old with only 180 hours seems early.
Anything else I should try?
Thanks.
Old 08-07-2017, 10:20 AM
swc5150's Avatar
swc5150 swc5150 is offline
Boat: 2015 Prostar
You could try to repack your rudder first, since it's a really easy and quick job. However, being your rudder turns easy when you disconnect the cable, that's more likely the culprit. A cable can easily go bad in 4 years unfortunately. I've seen them go bad even earlier.
Old 08-07-2017, 12:09 PM
kyfooter's Avatar
I figured. Was holding out hope for a better option.
I did find a pretty funny YouTube video about a "guaranteed" way to loosen a stiff steering cable. The guy goes to great length to force oil into the cable, and works it for several hours, before concluding the "guaranteed" way to fix the issue is to buy a new one.
Old 08-07-2017, 02:39 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
My steering cable was buttery smooth and died within a year. The culprit was a leak in my cover and the angle the boat sat at on the lift. Water would fill the back bilge and likely left the end of the cable submerged in bilge water occasionally. Once the water intrudes it corrodes and locks up in a hurry.
I now have a canopy on my lift and run the bilge pump religiously before lifting the boat out of the water.
2004 Prostar 197, ACME 843
Old 08-07-2017, 02:44 PM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Still under warranty?
-Mike
Old 08-07-2017, 03:20 PM
kyfooter's Avatar
I don't think it's under warranty. I believe 2013 was the last year of a 3 year warranty. In 2014 they went to 5 year.
Understood about the water in the bilge, but you can eat of my bilge...stays dry all the time.
