Old 05-06-2016, 06:00 PM
kyfooter's Avatar
kyfooter kyfooter is offline
Boat: 2013 197 WTT / 1992 Barefoot Sanger
Fuel Gauge Suddenly Stopped Working
Boat is a 2013 197:
Just got the boat out for the first time this year. Fuel Gauge showed 1/4 full on trailer...stopped and put 13 gallons in.
Put boat in water, gauge is reading 3/4 full. After 5 min, gauge drops to 1/2, then after 5 more min gauge drops to E.
When I turn the key to run (before starting engine), all gauges, including fuel gauge, move from 0/E to full, then back to 0/E before settling on actual temp, oil pressure, etc. But, the fuel gauge stays at E now.
Thoughts?
Old 05-07-2016, 08:29 AM
sodbuster88's Avatar
sodbuster88 sodbuster88 is offline
Boat: 2014 MasterCraft Prostar
Because it sweeps through the startup diagnostic, it's likely not a gauge issue or connection behind the dash. I would check the sender and connectors at that point. Check this thread out: http://www.mastercraft.com/teamtalk/...ad.php?t=48823
Peace..!
2014 MC ProStar
2011 Sport Nautique 200V
2004 Ski Nautique 196
2003 Sport Nautique 216
1993 MC ProStar 190 25th Anniversary Limited Edition
1989 MC ProStar 190
Old 05-07-2016, 09:26 AM
T-bone T-bone is offline
Boat: 2000 MasterCraft X-Star
Originally Posted by kyfooter View Post
Boat is a 2013 197:
Thoughts?
Sounds like it is working exactly like every other MC fuel gauge I have seen.
Old 05-07-2016, 09:33 AM
Cove Creek AD's Avatar
Cove Creek AD Cove Creek AD is offline
Boat: 2013 X25 5.7
Many of the 2013s had a recall on the fuel sender. The float becomes saturated and doesn't float and therefore reads empty. However when this happened to mine it read empty all the time
You should check with your dealer to see if you need the recall. I installed the new one myself last fall because it was easier than getting the boat to the dealer…took about an hour.
…my escape is to just get in a boat and disappear on the water.
Old 05-07-2016, 02:41 PM
LDA6339 LDA6339 is offline
Happened to us a few seasons ago. We opted to just do it by the hours instead of getting it to the dealer to fix it. It wasnt until it was in the shop for some engine work a few years later that we had it fixed. We have a 60 gallon tank and the boat burns anywhere from 5-12 gallons an hour. So every 4 hours we filled it up. We never ran out with this system but we stayed on top of it pretty well. I do like having a working gauge now though.
Old 05-08-2016, 12:23 AM
kyfooter's Avatar
Thanks guys. I heard from others there were issues with the fuel sender in 2013. Will see if it's covered or not.
Old 05-08-2016, 01:25 AM
AZX46OD's Avatar
AZX46OD AZX46OD is offline
Boat: 2014 X46 6.2L
Same here. I've been through several senders and floats on my 2013. So far so good with the latest version. They supposedly have a new design/supplier that fixes the issue.
Old 05-08-2016, 10:05 AM
MattsCraft's Avatar
I went through 3, well the second one we knew would fail because the 3rd rev was not in stock yet but had a week long lake trip and didn't want to go without a fuel gauge. My dealer is great, all 3 under warranty.
The new rev seems good, went all season and made it through the winter layup so far. It should be a warranty item and an easy 15 min swap out.
Old 05-08-2016, 03:53 PM
M3lelena's Avatar
M3lelena M3lelena is offline
Boat: Xstar 13
Hi Cove Creek,
same issue: gauge is stuck on empty and closest MC dealer is 3 hours plane!!!. do you ha a DIY link or tutorial ?? anybody that can help is also welcome to chime in
