Old 07-05-2015, 09:13 PM
kyfooter's Avatar
kyfooter kyfooter is offline
Boat: 2013 197 WTT / 1992 Barefoot Sanger
Replacement guide post sleeve
Anyone know if the black plastic guide post sleeve is readily available at plumbing or hardware stores? I'll order if needed but it seems like such a simple component that I should be able to find.
Thanks.
Old 07-07-2015, 11:47 PM
bet_on_black's Avatar
bet_on_black bet_on_black is offline
Boat: 07 X-Star MCX
It's thin wall pvc, schedule 30 and I haven't been able to locate it easily. If you find a good source please share.
Old 07-08-2015, 11:18 AM
Logan91077's Avatar
Logan91077 Logan91077 is offline
Boat: 2008 mastercraft xstar
Isnt it just 2" abs pipe? Home Depot. About $6 for 8' of it. Thats what it was on my CTW trailer anyway.
Old 07-08-2015, 11:19 AM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Home Depot has the sleeve.
Old 07-08-2015, 05:49 PM
joshbw joshbw is offline
Boat: 2011, x45, 6.2L
Was not able to find it so just got some sch40 black 2" ABS and caps. Took a hole saw the size of the metal pole and drilled the abs caps. Glued them together and have not had an issue, seems stronger than factory.
Also, we have steep ramps so I drilled a hole in the abs pipe for access, drilled and taped a screw into the metal pipe which now acts as a stop preventing the the abs pipe from floating off.
Old 07-08-2015, 06:11 PM
Miss Rita's Avatar
I bought some white PVC pipe in the right size at ACE Hardware, the two local big box hardware stores didn't carry the right size in ABS.
