Old 11-03-2017, 04:10 PM
tommurtha tommurtha is offline
Boat: Prostar 197 2003
water in battery box 2003 prostar 197
just pulled the battery and for the 2nd year in a row I had about an inch of water in the box. There is no drain hole. Doesn't seem to be a problem but you would think it would have a drain hole. Even my old 77 S&S had one
Old 11-03-2017, 04:58 PM
IBR IBR is offline
Boat: 2014 X-Star 7.4L Past: '99 Prostar 195, '01 X-Star, '07 X-Star
Same with my 2014 X-star. I usually put off pulling the boxes till the end of the year... Might need to see about adding a drain.
Old 11-03-2017, 05:02 PM
Shaun R's Avatar
Shaun R Shaun R is offline
Boat: 2011 X25
Is yours an actual box or is it the hole in the floor that my 96 Prostar had? I believe mine had a drain hole in it and it ran down to the bilge, not sure I would want my battery just sitting in water all the time.
Old 11-03-2017, 05:23 PM
jgraham37128 jgraham37128 is offline
Boat: 2016 Mastercraft X23
If it’s water from the battery it will eat everything up.
I wouldn’t put a hole for draining.
Old 11-03-2017, 06:09 PM
Aquaholic Aquaholic is offline
Boat: Mastercraft X2 2003 5.7 TBI
I believe no drain hole is by design. If your battery has a catastrophic failure you do not want all that acid running down to the bilge. My 03 X2 has no drain.
Old 11-20-2017, 10:12 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
You ever see aliens when the green blood spills on the floor?
I once dated a girl in high shcool and her dad told me I would never amount to anything. He was right.
Old 11-21-2017, 05:23 PM
my 01 has no drain so I went to add one.. that didn't work.. it is like a box in a box... the fiberglass doesn't have a drain anywhere either...
i just fire up the wet/dry vac and suck out the water...
Old 11-21-2017, 06:26 PM
mustangtexas's Avatar
mustangtexas mustangtexas is online now
Boat: 2005 MasterCraft Prostar 197 & 1989 190
Is the boat sitting out where it gets rained on? I am wondering how you get water in the battery box as I have not had that happen.
Old 11-21-2017, 06:32 PM
my boat is moored from May-Mid Oct, covered but the factory cover does leak and no matter how tight I adjust it, water will pool in a few spots. The covers are porous. However it get there, it stays all year I guess. Might even be accumulated condensation.
