Old 11-24-2017, 09:46 PM
EGRAY EGRAY is offline
Boat: 1993 205 prostar
1993 Prostar no NAV lghts
So I have power to blower, bilge pump and the AUX switches to the left... Just tried to go for a night cruise before winterizing and bam..... no lights... Pulled the dash and panel and nothing seems f...ed up so I assume I have a bad switch.. I may try and move the wires from the NAV to the AUX and see if the lights come on?? Not sure whats up.. Only thing I have done this summer was replace the ignition switch.. Can't recall if I have run the boat at night since replacing ignition..
Old 11-24-2017, 10:10 PM
good luck
John 14:6
Old 11-24-2017, 10:46 PM
tph's Avatar
tph tph is offline
No Nav lights
Have you tested the bulb?
Old 11-24-2017, 11:29 PM
It's front and back lights out... odd
Old 11-25-2017, 09:54 AM
12volts to switch? check ground. 1993 could be corrosion
Old 11-25-2017, 10:38 AM
SkiWest's Avatar
SkiWest SkiWest is offline
Boat: 1995 Prostar 205
I'd check bulbs too. All mine were out when I bought my 95. One thing I forgot to check before buying!
Old 11-25-2017, 12:26 PM
Miss Rita's Avatar
The nice thing about this era of boats (mine is a '92) is that it's very basic 12V wiring. No computers, nothing digital, just a hot wire, a breaker, a switch, and outgoing 18 ga wires to the accessory. It shouldn't be too hard to track down.
Old 11-27-2017, 01:22 PM
I may have messed the switch up when I was messing with it... Did not have my voltage meter at the lake house so I could not test it. Any idea where I could get a replacement switch that matches??? The ones that are original have a green light when turned on.. All of the other switches are working properly but the NAV green light does not come on and lights do not work..
Old 11-27-2017, 02:00 PM
Originally Posted by EGRAY View Post
I may have mess the switch up when I was messing with it... Did not have my voltage meter at the lake house so I could not test it. Any idea where I could get a replacement switch that matches??? The ones that are original have a green light when turned on.. All of the other switches are working properly but the NAV green light does not come on and lights do not work..
Those switches are hard to find. I am following the thread to see if you find a rocker switch like those.
John 14:6
Old 11-27-2017, 02:06 PM
Waterski.com is the closest I have found so far... not looking good...
