Old 06-17-2018, 06:56 PM
buckstwofifty buckstwofifty is offline
Boat: 2011 X25
Mysterious parts in found in X25
My port and Stbd tanks would not fill up(center did) and as we sat idle for five or ten minutes the engine started to overheat. The serpentine belt was shredded but I found other parts that I can't Identify. I was hoping that someone here could help me figure out if the belt tore apart something else on the engine. Here are a few pictures of the parts I found while cleaning up the belt. Hope someone can Identify them.
Picture 1-belt
Picture 2- rubber
Picture 3- hard plastic
Picture 4- hard rubber 6203LU are the letters on it
Thanks
Buckstwofifty
P.S. Any idea why ballasts would not fill?
Old 06-17-2018, 07:13 PM
FourFourty's Avatar
Looks like you’ve had an idler pulley fail......
The parts all look like they belong to a pulley and bearing assembly.
Old 06-17-2018, 08:05 PM
Moved2ski Moved2ski is offline
Boat: 2008 197
I second the idler pully.
Old 06-17-2018, 08:26 PM
Boat: 2011 X25
Just went out and checked and you guys were right.
Where is a good place to order a new pully?
Thank you very much.
Buckstwofifty
Old 06-17-2018, 09:05 PM
Boat: 2008 197
I donít know what engine you have but if itís a GM block any 5.7 Chevy truck pully will interchange. Auto zone should have on for about $15.
Old 06-17-2018, 10:45 PM
gweaver gweaver is online now
Boat: 2003 VRS 230 w/X-boat package, 8.1L
I had the same issue last week- bearing failure on the tensioner pulley. I did what Moved2ski suggested- local auto parts store, bought a new tensioner, idler and belt. If it was your idler pulley, might be worth changing the tensioner as well. Bearing is the same age, could be headed towards failure as well.
G
Old 06-19-2018, 11:17 AM
prostar205's Avatar
prostar205 prostar205 is offline
Boat: 2002, X30, L-18
That second pictures of the grommet you have in your hands appears to be the grommet that mounts between one of your ballast pumps and the boat. It is to damper the vibration of the pump. There should be 4 of those grommets per ballast pump. MC may of left one in the bilge by accident when they were making the boat. Keep it, I loose them all the time when I remove my ballast pumps for the winter.
