Old 07-17-2018, 03:03 PM
Shakey Shakey is offline
Boat: 2011 Mastercraft X14V
Warning: Service Required
2011 X14V
We've been getting an occasional "Warning Service Required" alert on the VDIG. Only happens when using Perfect Pass and running at constant RPM (~3800) for several minutes, like when skiing. Doesn't come on when we're just cruising around and varying the speed. Engine seems to be running fine. Oil pressure good. Temp good. We're 300 miles form the dealership. What kind of things trigger this warning?
Old 07-17-2018, 04:48 PM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
This can literally be any warning from the ECM. If you can't go into the menu and pull the actual service codes that are triggering this light, then you might need to invest in a code reader with the right connection type. Others who have owned boats with VDIG will chime in and tell us how to do this. Tim (CantRepeat) has a lot of knowledge about this.
Old 07-17-2018, 04:59 PM
Mastar Mastar is offline
Boat: 2009 Mastercraft X Star
Reset your oil change reminder. Probably not the cause but worth resetting. Keep an eye on your temp and volts. Sounds like it may be getting warm, when was your last impeller change?
Old 07-17-2018, 05:21 PM
Already reset the oil change reminder. I watch the temp and it's always 160ish. Haven't been watching the volts. I don't know then the impeller was last changed. I bought the boat used last fall.
Old 07-17-2018, 05:45 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
It’s probably not the cause, but you should change the impeller since you don’t know when it was last done. Most folks change them at least every other year (and remove over the winter) and many change every year.
Bailey
'02 X-9
Lake Blue Ridge
Old 07-17-2018, 06:21 PM
LDA6339 LDA6339 is offline
Boat: 2016 Mastercraft X-30 6.0L
Originally Posted by CruisinGA View Post
Itís probably not the cause, but you should change the impeller since you donít know when it was last done. Most folks change them at least every other year (and remove over the winter) and many change every year.
+1 to every year here. It usually works out to being about every 100 hours but this year it will be closer 125.
2016 X-30 6.0L
"YoU CaNt FiT 4 Rev10's oN a ZFT4"
2017 Nissan Maxima SL
Lonestar Masterbash
http://www.mastercraft.com/teamtalk/...ad.php?t=85369
Texas A&M '21
