Old 07-14-2018, 10:09 PM
Nor*Cal Nor*Cal is offline
Boat: 2003 Mastercraft Maristar 210 VRS MCX 350
2003 MCX Intermittent Power Loss
So I took my "new to me" 2003 out for the second time today and after warming up it intermittently lost power or bogged down, just for a moment and the check engine light would flash and the whole thing would go away for another 20-60 seconds. It did not seem to matter what RPM range we were going at...
After grabbing a beer to think about the bad decision that was this boat , I fired up and ran for 10 minutes without an issue. However, when I hooked up fresh water in my drive way and ran the boat in neutral the issue returned.
So I've searched here for the last hour and from the threads I have found it looks like a possibility of a few things:
1.) Fuel Pump Relay
2.) Fuel Pump
3.) Ignition Module
I just replaced the distributor cap and rotor and checked the spark plugs.
Any ideas? I have 5 couples flying in for a boating weekend next week and really need to get on top of this. Thanks!
Old 07-14-2018, 10:28 PM
mtajpa's Avatar
mtajpa mtajpa is offline
Start here I am sure its a poor connections in the fuel pump circuit or bad ground from the pump connector to ground. Google teamtalk bad fuel pump connections, You can start here.
https://www.mastercraft.com/teamtalk...ad.php?t=42197
99 MariStar 230 Sport LTR 330
Old 07-16-2018, 10:32 PM
Boat: 86 Magnum Skier
Since the computer recorded a fault pull the code. That will likely give you a good indication of what is wrong and where you should start.
Old 07-20-2018, 03:19 AM
At this point it looks like the the ecm is fried. Will post more details with the code and so on Monday.
Old 07-23-2018, 07:12 PM
Intermittent then no signal from the ECM to the fuel pump module. Then... the ECM completely went out.
$1500 later and things ran great for 8 hours on Saturday.
Anyone else have this problem?
Old 08-05-2018, 08:31 PM
Bruton Bruton is offline
Boat: 2003 mastercraft 230 vrs
i am having the same issue but without the check engine light coming on.
Old 08-05-2018, 10:23 PM
Yes, but we just powered the fuel pump relay from another source. 400 hours later it's still running strong
