Go Back   TeamTalk > Classifieds Buy/Sell > For Sale: Parts & Accessories
  #241
Old 04-17-2018, 11:09 PM
jesam jesam is offline
Boat: None
Perfect!
Old 04-21-2018, 06:18 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Parts arrived this week and I have a few ready. I'm going to ship them in the order that people confirmed. When I get to yours I'll PM you and email a paypal request.
Here is the starter module. Wires are labelled but I'll probably make a label for the front with wire color/function also.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Ballast Timer Reprogramming Info
Old 04-21-2018, 08:07 PM
BozickA88 BozickA88 is offline
Boat: 2009 197 prostar WTT
Great, so my boat does not have a seat heater but I do have the switch, I assume its ok to just use that switch instead of a hidden one to turn is on and off correct?
Old 04-21-2018, 08:37 PM
tr6coug's Avatar
Yeah, that would be perfect.
Old 05-03-2018, 10:21 PM
Boat: None
Is there any reason you cant eliminate the on/off toggle switch and ground the master module directly? I have no use for the toggle that i can think of.
Old 05-04-2018, 01:04 AM
tr6coug's Avatar
You can do that. The control module does pull a little current even when the boat is off so the toggle switch will allow you to switch it off completely. If you have a main battery switch then turning that to off would accomplish the same thing.
Old 05-04-2018, 01:10 AM
tr6coug's Avatar
Update. I've shipped about 2/3 of the starter kits. I'm moving this weekend so the next 1/3 will be a little later. I should be able to get those all out by the middle of the month though.
Old 05-23-2018, 10:14 AM
mcolinb mcolinb is offline
Boat: 05 XStar
Maybe this has already been covered in the previous 25 pages, but I attempted to install this yesterday and I found that my ignition wires are extremely short and made it nearly impossible to see what was labeled on the key ignition switch. Also, it seemed as though my instructions were created with the intent of keeping and re-mounting the key switch and didn't include references to the toggle switch. Any help would be appreciated.
Current: 05 XStar
Previous: 97 ProStar 205
Old 05-23-2018, 03:06 PM
tr6coug's Avatar
True, the instructions were created with keeping the ignition switch and using it as the cut-off. You don't need to do that you can use the toggle that was included as the cut-off switch. Its up to you.
For the short ignition wires, take a look at the diagram in the instructions that shows the back of the key switch. it will give you an indication of what wires go where on that switch. One diagram is for the type of switch that has accessory on a left turn of the switch. The other diagram is for the type that has accessory, on, start as all right hand turns of the switch.
You could extend the wires with an extra length of wire using wire nuts if needed. PM me if you need some more help/info.
