Old 06-21-2017, 02:36 PM
Hawgdriver's Avatar
Hawgdriver Hawgdriver is offline
Boat: '06 X2, GSA, Plug & Play Ballast
How much Hull water should cause concern?
I've tried the search function but haven't found what I'm looking for. I have an '06 X2 and I'm starting to take on more water than usual. 2yrs ago it would be almost dry after a couple hours of use. Now my front bilge sometimes kicks on once or twice for just a few seconds or so within an hour. From my search it doesn't seem to be an issue yet but once I pull the center drain plug it does drain for minutes and used to be less than 30" or so.
I've investigated the hose leaks, shaft seal, etc.. and can't find a source yet. Based on all your experience would any of you be concerned??
2006 X2: GSA, 820s in the rears, 600 X2 horseshoe in the bow, Rub Rail Docking Lights
Old 06-21-2017, 03:02 PM
Keith2230's Avatar
Keith2230 Keith2230 is offline
Boat: 2006 X-30 MCX
Do you have a dripless shaft seal or a conventional one? With a conventional that sounds about normal to may need a repack soon. If it's dripless then I still wouldn't stop until I found the source. You're not going to sink or anything catastrophic but I'd still want to know.
Old 06-21-2017, 03:27 PM
TXMC-06X2's Avatar
TXMC-06X2 TXMC-06X2 is offline
Boat: 2013 X25
I had an 06 X2 that did the same thing. I had 2 issues causing the water buildup. The metal strap that held the hose on the raw water pump wasn't tight enough and water was dripping from it when the motor was running. The higher the RPM's the more water it would shoot into the boat. Also, my rudder port was leaking. I had to send it off to have it rebuilt. Once I corrected those issues we were good to go.
Old 06-21-2017, 04:14 PM
snowman snowman is offline
Boat: Mastercraft, X25, 2012
I have the same issue. I saw water dipping from the intake of the raw water pump. I need to check the metal strap. but im not sure if i also have my dripless seal leaking not really a good way to check if it is leaking or not. I know at the end of the day it dips water down the outside of the Haul and drive shaft for 10 mins or so. Not sure if that is normal or not.
Old 06-21-2017, 04:35 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
I had the problem with a pinhole in a hose to the heater core. Under the floor, you couldn't see it until the hose was pulled out.
Old 06-21-2017, 05:00 PM
TN_Rider TN_Rider is offline
Boat: Malibu wakesetter
Can always put the boat on the trailer and put a garden hose in the hull and start filling it and see if water comes out anywgere
Old 06-21-2017, 08:52 PM
MC197indy MC197indy is offline
Boat: NotaMC
Old 06-21-2017, 09:54 PM
zsqure's Avatar
zsqure zsqure is offline
Boat: MasterCraft X-14, '09 Blue
One of my mufflers has a leak, my bilge gets water in it as well.
https://badges.fuelly.com/images/smallsig-us/302328.png
1988 prostar 190 SOLD
2001 Prostar 209 SOLD
Old 06-21-2017, 11:25 PM
Hawgdriver's Avatar
I must say that I'm not the original owner and I'm not sure what type of seal I have...how would I check to determine??
Old 06-21-2017, 11:26 PM
Hawgdriver's Avatar
I'll check this but I didn't see anything dripping. Maybe it's the shaft seal or rudder.
