Another reason to start the engine with doghouse open...check your cooling lines before and after you start to engine to ensure water coming from the impeller housing to the tranny cooler...also check for leaks and plug before you pull off the trailer. I would never pull off the trailer before ensuring everything is okay.
2 at 32' off 34 mph PB July 2006 |
#12
On the X2's it's even worse because the lanyard plug is right by the driver's drink holder. Inevitable to knock it off at least once a day getting your drink.
#13
Just removing the coiled cord and leaving the clip in place will still allow the switch to fail and wreck at least part of your day...........depending upon when you realize it is the cause of your engine not starting.
Launching without your plug seems inevitable. The sooner you get it over with, the less likely you are to do it again. ![]()
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#14
Same here, but I sometimes have a panic attack regarding the plug. I've never had a issue with the lanyard though, so far.....
#15
been there done that...new habit.. pulled it when i pull the boat out of the water...put it in before I leave the garage to go to river....or lake.
I'll wire the wires together before I pull the red chord off the clip. That dang clip will come off then it will be imposible to find since it has no red cord attached to it.
#17
Lanyard
I did the exact same thing.
Love my boat, hate my trailer. |
#18
Can't help with the lanyard, but try getting in the habit of hooking the plug through the loop of your key chain/float when you remove it. Hard to start without it when it's right there with the key.
-Chad 2010 X-14v previous 2001 MC Prostar 190, 1989 CC Ski Nautique 2001, 1984 CC Ski Nautique, 1979 CC Ski Tique |
