Old 08-08-2018, 02:18 AM
TribekampsurfersAZ TribekampsurfersAZ is offline
Boat: x30 2013
wake surf wedge with Gen 1 tabs?
Has anyone tried using a surf wedge with the Gen 1 tabs? What kind of results did you get?
Old 08-08-2018, 08:44 AM
GiantDO@X35's Avatar
[email protected] GiantDO@X35 is offline
Boat: 2012 X35 6.0 Ilmor
I have good luck using a listing method with lots of extra weight for port-side surfing. Port locker bag, bag on floor on port side, lead bags.
I have had very good results with a homemade suckgate for starboard side, but none of my crew surf goofy, so havenít used it much
Old 08-09-2018, 11:02 AM
Rhob88 Rhob88 is offline
Boat: 1994 mastercraft 205
The gen 1 tabs seam to make the wave longer and cleaner , but you will loose energy compared to no tabs deployed , that’s my experience on my x14v while using a wake enhancer on the side of the boat .
Old 08-09-2018, 11:03 AM
The gen 1 tabs seam to make the wave longer and cleaner , but you will loose energy compared to no tabs deployed , thatís my experience on my x14v while using a wake enhancer on the side of the boat . Sorry for repeat
Old 08-09-2018, 06:31 PM
samasm samasm is offline
Boat: 2013 X-30
I have the same boat - 2013 x-30. I use a quick shift wake surf wedge - placed in the middle position (it's adjustable) and suction cupped as far back on the boat as it will secure. I had gen 2 installed over the winter and run 750's in my rear lockers. I do not list. I still use the wedge when there are 3 or fewer in the boat - it really extends the wake and cleans up the lip even better than gen 2 loaded with people.
Old 08-26-2018, 11:21 AM
mindbender73's Avatar
mindbender73 mindbender73 is offline
Boat: Mastercraft X15, 2011 5.7 Indmar 310 H.P.
I have gen 1 tabs and they are worthless, no push from the surf wave, wave looks good just no push, I use a mission delta wave shaper and donít even deploy the gen 1ís
https://youtu.be/_f1PdXbANoY
Old 08-26-2018, 12:08 PM
I have Gen 1 and the key is to have enough ballast and to list it to the side of surfing.
I have a heavier boat with X-35, so requires more ballast than a smaller boat-I use about 2600# total with built in ballasts and pkug and play and additional bag on the floor and lead.
I have about 1000# at midship on the port side or slightly aft.
I tried filling both lockers with big bags and it just bogs down too much with Gen 1.
Old 08-26-2018, 12:10 PM
Shaun R's Avatar
Shaun R Shaun R is online now
Boat: 2011 X25
Played with this some last time out on my Gen1 X25. Regular wave with all ballast full and two 800s in the back as full as they can get. 40 center tab 40 surf tab and surf gate on the side. Very clean long wake with balanced ballast. Didn’t play with the goofy side as no riders that day but feel I will still need to lean the boat some.
