Old 12-23-2017, 09:02 PM
sten76's Avatar
sten76 sten76 is offline
Boat: 2015 X-23, 6.2L
Draft/Depth Question
If the X23 has a draft of 28", does that draft change with added ballast/weight? If so, how much? Is there an equation with added weight and draft?
Some of the local rivers have shallow depths and want to make sure it's all good.
Old 12-23-2017, 09:08 PM
1redTA's Avatar
1redTA 1redTA is online now
I’d load it down and measure what you have left
1981 MasterCraft
19' Skier 351W PowerSlot
Old 12-23-2017, 09:53 PM
yes draft is usually calculated from the lowest point of the boat at stock weight. so whatever you add will change that.
Old 12-24-2017, 08:28 AM
88 PS190 88 PS190 is offline
There are equations but you'd have to have more numbers about the hull displacement.
Easiest just to ballast heavier than you'd use it in application and find a maximum draft.
Old 12-24-2017, 09:56 AM
snork snork is offline
Boat: 07 xstar
you can add 3" of additional draft for every 1000#
Old 12-24-2017, 10:40 AM
You shouldn't have much to worry about if the boat is on plane, but don't go from WOT to idle instantly because the sudden drop in speed will make the boat settling much deeper than it is at rest.
Old 12-26-2017, 09:06 AM
DHPRO's Avatar
DHPRO DHPRO is offline
Boat: 2014 Gen II X30 SS
Ahhh...wouldnt it be deeper draft @ surf speed all loaded with ballast and pushing a wave?
Old 12-26-2017, 09:41 AM
With ballast is deeper than empty, but it's on plane, so the hull is riding higher with the weight distribution doing its thing as to how level the hull is. I would really want to know the river and the actual water level before doing this.
Old 12-26-2017, 07:52 PM
XC500mod XC500mod is online now
Boat: '18 x23, '15 x10
i thought the 28'' of draft on the x23 was with full ballast.
Old 12-28-2017, 01:19 PM
Loewen's Avatar
Loewen Loewen is offline
Boat: 2017 X23 6000GDI (previous boat was 2014 X25) (4 other boats prior, but none MC)
Send a message via Skype™ to Loewen
Guessing ours drops a solid 6" past stock draft when the ballast is full based on how deep the swimdeck goes underwater. More with a lot of people on board. X23 is a tank.
