Old 09-30-2018, 12:06 PM
Miss Rita's Avatar
gas mileage
My wife has a Mini Cooper S, and I have a VW GTI. Both are turbocharged, and both are an absolute blast to drive.
Premium fuel is recommended by both manufacturers, but I've been told by the respective dealers that it's OK to use mid-grade fuel, the engine computer will reduce boost and retard the timing to prevent detonation. Understandably, they will make less power. For my day to day driving I'm OK with only having 190 HP on tap instead of the full 210 HP. I get 30 mpg for daily driving, 33-34 mpg on the highway.
Question: is gas mileage decreased when I use lower octane fuel? If there's no difference, I can save $15/month if I use mid-grade instead of premium. If mileage improves by 10%, the extra 10% in cost is justified.
Old 09-30-2018, 12:12 PM
slalomjunkie slalomjunkie is offline
Boat: NA
Originally Posted by Miss Rita View Post
Question: is gas mileage decreased under these conditions? (I can save $15/month if I use mid-grade instead of premium. LOL!)
I've used both 93 and 87 octane in my vehicles and never noticed a difference in how many miles per tank. And no detonation. Not even in the boat.
In fact, i haven't seen a car do that since the mid 70s
Sent from my SM-G930T using Tapatalk
The sea, once it casts it's spell, holds one in it's net of wonder forever - Jacques Cousteau
Old 09-30-2018, 12:30 PM
calebbroege calebbroege is offline
Boat: Maristar 1995 275 hp
Upper grade fuel really is only needed for serious performance vehicles like sports cars or exotics for the most part
Old 09-30-2018, 12:39 PM
JimN JimN is online now
Save half a buck every day, eh?
Does your gas have Ethanol? You would be better off without that crap than worrying about high OR low octane.
Old 09-30-2018, 12:47 PM
Miss Rita's Avatar
Of course! Did I mention that we drive a Cooper S and a GTI? LOL!
Old 09-30-2018, 01:45 PM
lashburn1's Avatar
lashburn1 lashburn1 is offline
Boat: 2015 X20 SS
I was just doing the .50 a day math when I read your comments.
Funny right...I guess everything adds up if you find enough things to save a Buck or 2 on...
2015 X20 SS GEN2 6.0
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 10-01-2018, 11:50 AM
jharmon203 jharmon203 is offline
Boat: 2000 X-star
I would use what the manual recommends. The engine is programmed to get a certain type of fuel. If you aren't using that (especially with turbo charged engines), then you are potentially getting that much more carbon in your engine due to the need for more of a fuel requirement. If you save $15 a month, that's about 180 a year. See what is costs to get your turbo replaced and compare the differences.
I'm not a mechanic, but I have done a fair amount of reading on turbos (due to buying an f150 ecoboost) and you probably dont want to mess around with a different fuel grade other than the recommended one.
Old 10-01-2018, 12:26 PM
roadster02 roadster02 is offline
Boat: 1980 Glastron Carlson CVX-16 Deluxe w 1981 Evinrude 140
Fuel octane ONLY has to do with the compression ratio of the engine. There is no more power, or fouling, or carbon production in the engine, or any other "urban legend" effect caused by high or low octane. 100 octane = the same power produced as 86 octane. Higher octane fuels have additives to reduce detonation in high compression engines, that's all. If you use a low octane gas in a high compression engine you can cause "pinging" which is pre ignition of the fuel and this can damage an engine, so, higher octane gas has an additive the helps by retarding the ignition point of the gas so that the heat of higher compression will not detonate it prematurely. Use a lower octane and listen to your engine, if it pings on hard acceleration, or when pulling a load, go up in octane. Better yet, read the owners manual and just use what is recommended for your vehicle.
Old 10-01-2018, 12:32 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
$15 bucks savings?
Use premium. Do not listen to your dealer, they didn’t manufacture the engine.
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 10-01-2018, 01:04 PM
neil.anderson63's Avatar
Boat: 2007 X2
Wife drives a GTI - 100% Premium fuel. We figure it’s pennies to avoid major dollars in repair bills.
Amazing car. I think she gets higher MPG running Premium vs lower grades of fuel.
