Old 06-12-2018, 11:36 PM
Fullpass's Avatar
Fullpass Fullpass is offline
The 8600002 is a 95 AMP Delco Remy 11si...if your boat had an OEM Delco Remey then yes a SKU WILL TELL YOU WHAT YOU HAVE. What is the SKU on your old alternator.
Old 06-15-2018, 10:22 AM
jamis0n jamis0n is offline
Boat: 2000 X-Star
Using the engine serial number, Bakes helped me confirm that this is the original OEM alternator:
https://www.bakesonline.com/alternat...no-pulley.html
And this is an upgrade kit that Indmar sells for that application:
495108 KIT ALTERNATOR UPGRADE 70AMP SERPENTINE $350.00
Finally, Bakes confirmed the case size of the Delco Remy 95AMP is the same as that 70AMP upgrade kit.
Ordered that and will post back once its installed.
Old 06-19-2018, 02:20 AM
Tsumi Tsumi is offline
Boat: 2001 X-star 5.7L LTR, 2000 Prostar 190 5.7L LTR, both dark green
Replaced ours with a 95 amp 11si marine alternator for about $80. Works perfectly so far... after adding a diode to the harness. Rock steady 14 volts instead of the previous 13 volts. Only had to shave a little bit of the housing with a file, took less than 5 minutes.
