Old 06-18-2015, 09:27 AM
k2rider's Avatar
k2rider k2rider is offline
Boat: 2011 X-Star 7.4L
Ilmor 7.4L Oil Change
Coming to that time to do the oil change. The owner’s manual says 5W-50, but when my dealer gave me a spare quart they gave me a 5W-30. What have you guys been using in the 7.4L for oil? Also, what oil filter should I pick up? I can’t seem to find one in the owner’s manual. I decided to try to find everything at work today to try to pick everything up for the weekend and haven’t stuck my head in the engine compartment to check to see the numbers.
Old 06-18-2015, 10:20 AM
FourFourty's Avatar
FourFourty FourFourty is online now
I'd stick with 5-50 full synthetic. Most auto parts stores will have Mobil 1 in that viscosity rating.
Oil filter is a Wix 51372 IIRC.
Old 06-18-2015, 11:09 AM
DocPhil DocPhil is offline
Banned
Boat: 2016 G23 H6
I thought the Ilmor manual called for 15W-50 Mobil 1. That is what I am going to use
How many quarts does this beast take 440?
Old 06-18-2015, 11:46 AM
Banned
Boat: 2016 G23 H6
Found it. Manual recommends 5.5 qt of Quaker state synthetic or Mobil 1 5w-50
Or Mobil 1 15w-50
http://www.ilmor.com/user_area/conte...-05-14-v-6.pdf
(Sections 11-1 and 11-2 in the Ilmor manual)
Also the oil filter is a MV8V-1021 which cross references with a wix 51372
http://wixfilters.com/Lookup/Interch...MV8V-1021&o=me
Old 06-18-2015, 02:15 PM
k2rider's Avatar
Thanks guys.
I can find the oil filter local, but can't seem to find Mobil 1 5w-50 anywhere local at all and it seems like it's only sold at a lubricant store online or from Mobil 1 themselves. If I go with 15W-50 is there going to be a big difference between them? I know the 15 is going to be heavier but any reason to track down the 5W?
Old 06-18-2015, 02:41 PM
Banned
Boat: 2016 G23 H6
Originally Posted by k2rider View Post
Thanks guys.
I'm not sure.
I think 440 runs 15w-50 don't you buddy?
I ran it in the LS3 in my Malibu and it did fine.
Old 06-18-2015, 03:49 PM
FourFourty's Avatar
Well, 15-50 is going to be thicker, and delayed on distribution through the engine, on those cold winter starts....... So, if you are going to run in sub freezing temps, I would run 5-50. Otherwise, you are good with 15-50.
Yessir, Doc. 15-50 is what I run.
Both viscosity ratings are recommended by Ilmore
Old 06-18-2015, 04:15 PM
k2rider's Avatar
Ok sounds good thanks guys. I’ll hit close to freezing temps in the late fall up here for air temps but not water and nothing I have to worry about anytime soon. Plus the 15-50 is in stock in a bunch of stores around me which is always a plus.
Old 07-30-2015, 10:16 AM
k2rider's Avatar
Bumping this back up. Need to do another oil change and used my buddy's oil extractor last time. He's away for work and I don't feel like always relying on him being around to borrow his stuff. I'm going to be picking up the west marine oil extractor tonight. The question is, what fitting do I need to attached it to the drain hose on a 7.4? I read a bunch of threads but everyone seemed to have different sized hoses than the ones listed for this pump.
The extractor:
http://www.westmarine.com/buy/west-m...6-5l--11047123
Old 07-30-2015, 10:34 AM
Banned
Boat: 2016 G23 H6
K2rider, don't get that pump from west marine. Spend a bit extra and get this one
http://www.pbsboatstore.com/Jabsco-1...bzrBoCkmjw_wcB
The fitting you need is a brass fitting with 1/2 inch barb x 1/4 inch male thread. It will fit the hose from that jabsco pump and the ilmor drain hose (assuming 2012 was a 1/4 inch male just like my 2015)
