Old 10-03-2016, 09:10 AM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Winterizing Q&A
Let's get a thread to answer questions about the winterizing process.
My first question, when winterizing an Indmar 5.7 motor, I purchased Rotella T 15w40 (If I remember correctly) but it's Diesel oil. Is this okay? My google searches said yes, but I want to double check with the pro's.
I'll also add, living in Kansas City we get pretty cold air. I've had that -50 pink antifreeze sitting in my garage before, and it was frozen into what looked like a slushy. This was in air temps that were just single digit... we're not talking the extreme cold you see up north further sometimes. When I saw that, I stopped using the pink stuff and just drain the boat, and leave it dry. Haven't had an issue yet (knock on wood).
-Mike
Old 10-03-2016, 09:17 AM
Wakerider16 Wakerider16 is online now
Boat: 2001 Prostar 205V
Even if the pink stuff turns slushy I do not think it will be a problem, the real problem is that when it completely freezes and begins to expand. As long as the volume remains the same no problem should occur (theoretically).
Old 10-03-2016, 09:19 AM
mzimme's Avatar
Agreed, the problem is, it has to be at full concentration to hold that -50 rating. Even a little bit of water left over in the motor dilutes that and significantly drops that -50 rating.
Winterizing dry works for me... Your results may vary.
-Mike
Old 10-03-2016, 09:25 AM
moosehead's Avatar
moosehead moosehead is online now
Boat: '15 X10 6.0L, '15 X30 6.2L
Air don't freeze. You could run the pink to dilute any supposed water pockets and then drain it?
Old 10-03-2016, 10:33 AM
Gavin Gavin is offline
Boat: 2004 Malibu 23 LSV, 1990 Prostar 190
I drain the water then add the pink just to be sure. Dry would be fine if you're 100% sure you didn't miss anything. I think the pink also helps with corrosion resistance. Didn't someone on here do a corrosion experiment awhile back? It was interesting but I don't remember the results.
I'm an Indy Skiers member. Contact me about course skiing in Indianapolis.
Old 10-03-2016, 11:16 AM
mzimme's Avatar
So, how bout the Diesel oil question?
-Mike
Old 10-03-2016, 11:19 AM
bandit628 bandit628 is offline
Boat: 2000 X-Star, 330 LTR
I have a 5.7 ltr, always run 15w40 Rotella. No issues for me.
Old 10-03-2016, 11:20 AM
bturner2 bturner2 is online now
15-40 Diesel is the correct oil.
Old 10-03-2016, 12:01 PM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
Here's one: ( sort of rhetorical because I know the answer) but I'm running anti freeze through my boat, and saw pink come out of the exhaust. Am I covered?
Answer is, no. Unless the thermostat is open, or do you have dry blocked before the antifreeze, the antifreeze likely bypassed the engine, and went straight out the exhaust. Thermostats let water out of the engine, not into it
Old 10-03-2016, 12:05 PM
moosehead's Avatar
Q: How many TT members say goodbye to their MC at hibernation, give a little pat on the hull, or mebbe a hug?
A: All of us
