Old 06-22-2011, 10:30 AM
I guess it would help if the OP would tell us what year his boat was.
Old 06-22-2011, 10:50 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
What year is your boat? On my 06 I have at least a 2.5 inch and could be a 3 inch thru hull with 1 inch feeder lines.
Mine is a 2003 X2.
Old 06-22-2011, 10:55 AM
JRW160's Avatar
Boat: 2003 X2
Originally Posted by kevkan View Post
I've got a 2008 X-1. I fill the tanks till water comes out the side of the boat. But when draining, is there some way to know when the tanks are empty?
I haven't looked, but I assume on mine there is a check valve on the fill line and that is how water is forced out the sides of the boat when draining. I could be completely wrong, but it doesn't seem like that we be much trouble to add.
Old 06-22-2011, 11:06 AM
JRW160's Avatar
Boat: 2003 X2
OP boat's is a 2006 X45 according to his sig
Old 06-22-2011, 11:49 AM
weird i cant see any sigs.
Old 06-22-2011, 12:27 PM
kevkan kevkan is offline
Boat: Mastercraft 2008 X-1
Yes, the 08 X-1 drains out the bottom, but does not have any guages, and I'm pretty sure there isn't a timer. I've been opening the center locker to watch the bag empty and knocking on the side of the tanks to determine if they are empty. I don't much care for the design.
I'm considering replacing the tanks with 750 lb bags, and adding the v shaped bag under the front. Just not sure if I wan't that much weight.
Old 06-22-2011, 12:37 PM
JRW160's Avatar
Boat: 2003 X2
I just replaced my factory hard tanks with 750s, and I also havethe ski locker sack and the v shaped bag up front. You are going to need more weight in the nose if you plan on filling the 750s. When I fill the 750s, I have a 350lb sack in the walkway and another 350lb sack laying perpindicular to it across the seats in the bow. If I had to do it over again, I might have just gone with 550s instead.
Also, I'm not sure what the stock prop is on an 08 x1, but I had a 14x20 prop on mine, and it would barely plane out with the boat weighted. I just switched to a 14.2x14.5, and everything is fine.
Old 06-22-2011, 01:58 PM
emnesto emnesto is offline
Boat: 2006 X45 LQ9
Thanks for all your help. My boat is an '06 X45, and I do get water out the sides when emptying. Do the guages reflect actual liquid in the tank, or the length of time the pump is running. I finally got all guages to empty, and I'm going to turn batteries off, then on, to reset the system. I'm also planning on replacing all 3 impellers this weekend with green. I'm still on the original impellers, so that should help.
2006 X-45 LQ9
2005 Yukon Denali
ballest, operation, pump
