Old 06-23-2018, 07:06 PM
tr6coug's Avatar
tr6coug tr6coug is online now
Boat: Mastercraft 2007 X2 MCX
MCX Engine losing power at low RPM
My '07 MCX is loosing power at low RPM. Last week on the lake at around 1500 RPM it would briefly drop rpms and sometimes die. Started up OK and idles OK. At higher RPM it runs better but not perfect. I'm not getting any check engine warning!
So, I immediately thought it was a fuel pump/filter. Today on the drive way I put a pressure gauge on it and its holding steady at 56 psi even though at 1200-1500 rpm the revs go up and down about 100 rpm.
This is the original fuel pump & filter and I do have a replacement pump and filter, but I don't want to pull that out of the tank if its not the problem.
Any ideas?
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Ballast Timer Reprogramming Info
Old 06-23-2018, 09:10 PM
snork snork is offline
Boat: 07 xstar
depending on the engine hours, it could become a problem, change it out and be done with it
what youre experiencing could also be bad gas
Old 06-23-2018, 09:19 PM
tr6coug's Avatar
It might be bad gas. I'm changing out the plugs, wires, distributor and rotor now since that hasn't been done in several years. If its still acting up I'll fill it with non-ethanol and see if it improves.
Old 06-23-2018, 09:48 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
Sounds like bad gas to me.
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 06-23-2018, 10:33 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
I’m not sure what it is, but checking fuel pressure in the driveway with no load is not the same as checking under load. Takes a lot less fuel to rev in the driveway vs pushing the boat to speed. However, I would expect a fuel supply issue to show up more at higher speeds than moderate like you mention
Bailey
'02 X-9
Lake Blue Ridge
Old 06-23-2018, 11:55 PM
tr6coug's Avatar
I changed out the cap/rotor and plugs. It seems to be running better now on the driveway. Taking it to the lake tomorrow to give it a good test.
Old 06-24-2018, 08:35 AM
jj4smith jj4smith is offline
Boat: mastercraft, maristar, 1995
Iíve been having a similar issue. Did you end up testing it?
Old 06-24-2018, 09:10 AM
Sodar had an issue where the engine would hunt at low rpm. Turned out to be a bad pedal position sensor at the helm. If that turns out to be the case this thread has the part number and is 80 bucks.
https://www.mastercraft.com/teamtalk...ad.php?t=56678
Old 06-24-2018, 05:40 PM
tr6coug's Avatar
So it IS the fuel pump. Got to the lake today and around 1200rpm fuel pressure was all over the place. Up near 50 then down below 20psi.
Old 06-25-2018, 09:23 AM
Cumminscj Cumminscj is offline
Boat: 86 Magnum Skier
Let us know if the pump fixes it. Sometimes fluttering fuel pressures can be the regulator.
1986 Marlin Magnum Skiier-sold
2000 Maristar 210VRS-weekend ride
1996 205 with LT1 cracked block-winter project
