  #31
Old 05-30-2014, 11:29 PM
uplander uplander is offline
Boat: MC 2002 X30
this is a good method to install new seal
Once you pry out the old seal, place the new one in the hub. Use a block of wood over the seal and gently tap it into the hub until it is flush all the way around.
Old 05-31-2014, 09:53 AM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
Sounds good. Thanks again.
Old 06-03-2014, 08:22 AM
Update.. I got the oil seals from etrailer.com and they also were the incorrect ones. After I installed everything and filled the hub with gear oil it all just leaked out from the back seal. I called etrailer back and they will refund my money but they are not able to tell me what size I need nor do they know what to sell me. I am frustrated. The guy at etrailer said they need to know the size of the axle to figure out what size seal to sale me. Anyone know how I can get this info?
Old 06-03-2014, 09:53 AM
Table Rocker's Avatar
Post #27 in this thread has the Reliable manual. You need a seal with an I.D. of 2.125. You can use National Seal #413470 available where you started at Advance Auto.
'96 ProStar 205 SD LT-1
Old 06-03-2014, 11:23 AM
Well that blows.
Need to get this added to the FAQ!!
Tim
Old 06-03-2014, 11:32 AM
I am headed back to advance auto parts today and hopefully can get the seal installed tonight and ill post an update. Thanks again.
Old 06-04-2014, 03:54 PM
Duplicate
Old 06-04-2014, 03:56 PM
I'm sure someone has mentioned before but is the process to install the seal as follows-
install larger bearing into hub
install rear seal into hub
put hub on axle
install smaller bearing in hub
put washer on axle
put castle nut on
put cottle pin in
fill hub with oil
put disk brakes on
put wheel on
My question is that are these steps in order? And do I need to do anything to the seal before or after I install it?
Old 06-04-2014, 07:22 PM
Success. I installed everything with new brake pads and it does not leak. Test drove it around the neighborhood and it was good. Thank you everyone for your help and advice. These seals cost 11 bucks from advance auto parts.
Old 06-04-2014, 09:14 PM
Good fix, was it National Seal 413470?
bearings, brake pads, hub, oil bath, trailer
