Old 07-20-2015, 10:37 PM
osmonet's Avatar
osmonet osmonet is offline
Boat: 2008 X2, MCX
MCX Thermostat change, am I being paranoid.
I'm getting temperature swings on the gauge between 165-200, and it doesn't ever really stabilize. As such.....planing on changing the thermostat on my 08 MCX.
Am I being paranoid, or is there a real chance of snapping the bolts? There looks to be a bit of hard water build up on one side.
Engine is a indmar crate engine replaced by dealer 2 years ago. According to records, thermostat was changed at that time. After the engine swap, previous owner put on 12 hours, but in brackish water. I since put on 40 more in fresh water and flushed and drained the engine last fall during winterization (about 15 hours).
So.....am I being paranoid with the bolt snap? Tell me this is noting like those damn tower bolts that seize in place.
Old 07-20-2015, 10:50 PM
soak in a good penetrating oil - let it sit for a few days then spray some more.. wait again... then give it a try with a short handled wrench... then try tapping the wrench with a hammer... it's those long breaker bars that spin the heads off bolts.
Old 07-20-2015, 11:03 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
Follow Mike's suggestion and you will be fine.
We defy the mafia!
Old 07-21-2015, 07:05 PM
osmonet's Avatar
Boat: 2008 X2, MCX
ok. Thanks guys
Old 07-22-2015, 07:10 PM
Swordfish Swordfish is offline
Boat: 2004 X10 MCX
Easy job if you have the right tools. There are 3 bolts, 2 - 9/16 and 1 - 1/2 inch. Use a 1/4 drive nine inch wobbler extension for the two 9/16 bolts. A 3/8 drive didn't work for mine as the throttle body gets in the way. The other 1/2 inch bolt is a piece of cake. Trying to use a wrench those bolts is not fun.
Don't forget to apply some anti-seize to those threads for next time.
Old 07-22-2015, 07:28 PM
osmonet's Avatar
Boat: 2008 X2, MCX
Thanks for the response, but I only see two bolts. Please advise.
Old 07-23-2015, 03:53 AM
Gert Gert is offline
Boat: Prostar 190 - 2004 - MCX
This is mine, boat is from 2004, dunno if it were two or three bolts:
brackish, mcx, thermostat
