Old 06-22-2009, 10:30 AM
Scottiepipn33
Guest
Posts: n/a
Engine Help please
I have a 2001 X-10. When the boat is in neutral, the engine runs and rev's up fine. But once I put it in gear, and hit the throttle, it backfires and will only go about 5mph at full throttle. Does anyone have any ideas of what it might be? I have had it in the shop and still am having the same problem. Any help or suggestions would be greatly appreciated!
Thanks!
Old 06-22-2009, 05:04 PM
Scottiepipn33
Guest
Posts: n/a
It also backfires... But there is a new fuel filter, so I am stumped to what could be wrong, maybe something electrical?
Old 06-22-2009, 05:10 PM
bigmac bigmac is offline
MC Platinum
Boat: 2004 Maristar 230 VRS
Timing may be off. Another possibility is plug wires out of normal firing order.
'04 MariStar 230VRS/MCX
Old 06-22-2009, 05:45 PM
corey's Avatar
corey corey is offline
Boat: X10
Check the plugs and wires, my guess is one (or more) of them is bad.
Old 06-23-2009, 01:20 PM
MCVOLS's Avatar
MCVOLS MCVOLS is offline
Boat: '08 X14 MCX Slot
Had a similar problem after a tune up. Not as bad as yours sounds, but would backfire under a load. Idle was fine. Re-checked the 'new' plugs, and one was cracked. It got worse as we continued to run, I guess the crack got worse as it heated up. As mentioned, plugs/wires/timing sound like a logical starting spot.
2008 X-14 MCX
1993 Prostar 205
1982 S&S
2001, mastercraft, x-10
