Old 06-19-2009, 09:43 AM
Taskmaster Taskmaster is offline
Normal running temp for '79 SS?
What is the normal running temp for a 1979 Stars and Stripes? Has a 143 degree thermastat.
Old 06-19-2009, 10:00 AM
Gamble's Avatar
Gamble Gamble is offline
Boat: Mastercraft Prostar 209 310 Predator
should be around 140 w/that thermostat............you running a 351W I'm assuming.
Old 06-19-2009, 11:25 AM
thwack's Avatar
thwack thwack is offline
Boat: 1979 19 Skier w/351-W
I just sold my 79 S&S two days ago and I have a few friends with early 80's S&S boats. They typically run between 150 and 165. However, if you have a 143 degree thermostat in your 351, it should run around that temp. The thermostat should govern the operating temperature as it opens to allow cooling water to run through when the temp reaches that point.
Old 06-20-2009, 07:54 PM
Thanks for the replies. We have been fighting with it running this year and decided it was time to update a few things. Electronic ignition, replaced all sending units, and non-working temp guage. So was curious on normal temp.
Now we are having hot start problems so time to rebuild starter. This boat is a head turner, just replaced decals and buffed out gel coat. We look cool as we get towed back to the dock. :-(
Old 06-20-2009, 08:30 PM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
Normal idling and running on plane, no load, 145 to 155 degrees engine temp.
As for hot start problem, before you rebuild the starter, check the timing, should be 6 degrees BTDC @ 600 rpm at idle in gear.
Normal idle in neutral, 850 to 900 rpm.
Charter Member Number 1
Quote: 2RLAKE,
Old 06-22-2009, 12:33 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
All of my PCM Fords with the 143 stat run a touch under 160.
Old 06-22-2009, 08:03 PM
stars-stripes08 stars-stripes08 is offline
I have a 78 S&S just out yesterday with it and it was a tick under 150 at its hottest point and that was after several laps around the lake with my son skiing behind it. I run around 27 MPH he is only 70 pounds and 9 years old.
Old 06-23-2009, 04:13 PM
jenglin's Avatar
jenglin jenglin is offline
Boat: '04 X9
My 88 TriStar 190 runs 200. Should I look at a different thermostat or a new impleller? I just changed my impleller last year.
Old 06-23-2009, 04:17 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
this seems a bit hot. I would check the impeller first then the T-stat may have the wrong one in there
Originally Posted by Hoosier Bob
She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
Old 06-23-2009, 04:50 PM
Commandohorn Commandohorn is offline
Boat: 1989 Prostar190
Owners manual says 165 to 195 for my 89 Prostar.....
1989 ProStar 190, the floating Porsche!
