Old 03-15-2007, 07:51 PM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
Originally Posted by H20skeefreek
I use margarine, it works better than butter, it doesn't taste as good though.
Have you seen the new Country Crotch "I can't believe it's no rudder grease"!
Charter Member Number 1
Quote: 2RLAKE,
Old 03-15-2007, 07:52 PM
bigmac bigmac is offline
MC Platinum
Boat: 2004 Maristar 230 VRS
Originally Posted by TMCNo1
How about KY Jelly???????????????
Can you get that for use in grease guns? And if so....
....never mind...on second thought I don't think I wanna know...
'04 MariStar 230VRS/MCX
Old 03-15-2007, 08:38 PM
stumbledog stumbledog is offline
Boat: 1993 Prostar 190
Be Careful
Originally Posted by east tx skier
Turn the wheel all the way to one side and give it two full shots. Then turn it all the way to the other side (back and forth a few times). Have a rag handy as it will squirt out a bit.
A big yes on the rag. When I shot grease into the fittings and turned the wheel, grease shot back out of one of the fittings.
Be Careful
click happy....sorry.
Old 03-15-2007, 08:52 PM
MC Hero
Boat: Gone
[quote=stumbledog]
The aluminum tube with the fitting on it does not have a ball in it that acts as a check valve like most zerk fittings and it will spew grease out, because if it was full of grease, it would lock up the steering cable. Someone I knew, replaced the zerk fitting, thinking it was bad, filled up the tube, put everything back together, went to the lake and the steering wheel would not turn and had to go back home and wait for a new tube from the dealer, because he couldn't find the old fitting he threw away. All he had to do was remove the fitting and the excess grease would have squirted out and allowed the steering to work, then he could have put in a new open zerk fitting. 2 pumps of grease is all that is needed.
