Old 10-15-2018, 05:06 PM
Maxime Maxime is offline
Boat: X2 2004
Engine error code Indmar 350TBI
Hi everyone,
I have a problem with my X2 from 2003 with indmar 350tbi. It can't get over the 2000rpm in gear I tried to pull the code with the paperclip methode. It flashes me these codes..
anyone who could help me what this means?
Thanks!
Old 10-15-2018, 05:42 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Movie doesn't play. My thread on paper clip method should have code list too
Sent from my SM-G920R6 using Tapatalk
2004 Prostar 197, ACME 843
Old 10-15-2018, 05:47 PM
codes 42 and 81
I think I answered this on FB - but here's more..
Check voltage on injectors - s/b 12v
Most likely ignition module - for code 42 - 42 indicates fault from ECU to ignition module - tan/black or tan/white wire. If wire is good and not shorting to block or anything - most likely ignition module. If wire bad - repair wire
Code 81 -
Test voltage to Fuel injectors - s/b 12 volts... if not correct inspect wires. Pink/green and blue wires - if wire bad repair clear code -
Test fuel relay - if it checks bad replace-clear code.
If problem persists test Engine Temp Sensor and ECT. - I am getting all this from the clymer manual.
