Old 06-30-2018, 02:02 AM
rapidwake rapidwake is offline
Boat: 2012 Mastercraft X2
Disabled Ballast and Wake Plate => Bow Up 2012 X2
New to me Boat and First time forum user
On our lake, we had to disable the Wake Plate and disable and empty the ballast. The 2012 X2 is riding Bow Up and I can't easily get the boat on plane. This boat has the Power Tower.
The Trim DOWN button does not seem to help at all.
Any suggestions on how to resolve this?
Thank you!!
Old 06-30-2018, 09:03 AM
bcd bcd is offline
Boat: 2014 X-2
The x2 doesn't have a wake plate. It has a trim tab, called attitude adjustment plate. It engages to make a smaller wake, not larger. If you disabled a plate, you disabled the trim tab, which is why you can't lower the bow.
Sent from my SM-G930V using Tapatalk
Old 06-30-2018, 10:26 AM
neil.anderson63's Avatar
Boat: 2007 X2
What speed are you going and the bow stays up? I don’t have a trim plate on my X2; I don’t experience what you’re describing above surf speeds.
I’ll buy your “wake plate” since you can’t use it.
Old 06-30-2018, 11:38 AM
Shaun R's Avatar
Shaun R Shaun R is offline
Boat: 2011 X25
Lake Oswego? I would argue that the center tab is a wake limiting device and should be left alone. Surf tabs on the side should be turned off.
Old 07-01-2018, 12:07 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Need more info. Boat will take off and plane out just fine without tabs or ballast. Mines been doing it for 13 years now!
Actually nose lower if rear ballast is empty.
'06 X2 MCX
Old 07-01-2018, 07:59 AM
bturner2's Avatar
bturner2 bturner2 is offline
I have yet to see a MasterCraft that hasn't been modified or improperly loaded that couldn't get on plane. You either have a mechanical problem (slipping trans, entirely the wrong prop, etc.) or possibly you have the Perfect Pass set to something like 10 MPH.
A 300+ HP 20' ski/wakeboard boat is going to plane with or without tabs if it isn't broken or being operated improperly.
Old 07-01-2018, 01:19 PM
Thrall's Avatar
Boat: '06 X2 MCX
Rapid wake, you may want to brush up on the workings of your boat too, if you disconnected the trim tab and then expected the trim switch to do something meaningful.
'06 X2 MCX
