Old 06-25-2017, 12:59 PM
Canwan Canwan is offline
Boat: 2008 MC X2 MCX
Thread sealant
I bought a wake makers piggy back additional tanks for my x2. Should I be using pipe sealant on the threaded fittings? There are absolutely no instructions with the kit.
Thanks
Old 06-25-2017, 01:05 PM
Kell's Avatar
Kell Kell is offline
Boat: 2009 X2, MCX
No thread sealant is required. Just hand tight. I just got a set of WakeMakers bags for my X2 and called customer support to confirm.
09 X2, MCX 350, VDig, PP, Heater, Shower, Bow Filler Cushin, Bimini, Wake Plate, 2 Tower Speakers w/Forward integrated docking lights, Tandom Low Profile Trailer
Old 06-25-2017, 01:12 PM
Thanks!
How did you connect to the overflow? Did you use a joiner to connect the existing hose to the wake makers hose or did you run the new hose right to the outlet elbow? Seems like a lot of extra hose either way.
Old 06-25-2017, 01:39 PM
Kell's Avatar
Boat: 2009 X2, MCX
I disconnected the overflow directly from the through-hull fitting (elbow which came off much easier than than the tank hose/barb) and connected the overflow from the WakeMakers pre-assembled kit. The over flow hose from the WM kit is a bit long, so I may cut that down 4-6 inches or so so the tee-sections will lie flat against the side of the hull. I have the WakeMakers instructions and pictures provided by customer support and would be happy to PM those to you if it helps.
Old 06-25-2017, 01:57 PM
I would really appreciate that! Thanks
Did you get the bow ballast as well?
Old 06-25-2017, 02:08 PM
Kell's Avatar
Boat: 2009 X2, MCX
No, just port and starboard locker sacs (460lbs each).
Old 06-25-2017, 11:22 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
A hair dryer or heat gun really helps to get the hoses on and off the barbs.
We defy the mafia!
Old 06-25-2017, 11:30 PM
Thumbs up
Thanks for the tip!
