Old 06-03-2017, 08:05 PM
Soder's Avatar
Soder Soder is offline
Boat: 2004 X-30 MCX
Exclamation Ballast Pump Fills but Won't Drain
Thought I'd post this in the interest of a database of solutions.
My port pump has always filled just fine but struggled to drain properly. I could hear it working and the impeller was fine.
As I was upgrading to 1" hose to feed my TankBuster kit from WakeMakers, I removed the 3/4" barbed hose fitting and found the problem.
As you can see from the picture, this fitting was cross threaded and probably the stress introduced a small hole that prevented my pump from creating a vacuum during self-priming. Compare to the other fitting I removed from the other pump.
I may have never found it if I was not upgrading to 1" hose.
I hope this helps someone out there.
2004 X-30 5.7L MCX
