Old 07-02-2018, 08:51 AM
EJ OJPROP's Avatar
EJ OJPROP EJ OJPROP is offline
This is one of our very early systems. I would suggest an upgrade to the new system which is water cooled. Please give me a call for more info.
Eric Johnson
Johnson Propeller Co., Inc
[email protected]
ojprops.com
800-359-9730
Old 07-02-2018, 11:32 AM
ldelosreyes12 ldelosreyes12 is offline
Boat: 2005 X10 - MCX 5.7L
Seal
Thanks, Eric!
Old 07-06-2018, 06:27 PM
New dripless shaft seal
Bought a new dripless shaft seal system from Eric at OJ Props.
Eric Johnson
ojprops.com
800-359-9730
Old 07-20-2018, 02:02 AM
New Glide dripless shaft seal
Here's the new system installed. I tied in the tee to the water intake hose. Hope that's right...
Old 07-20-2018, 08:12 AM
dbismyname dbismyname is offline
Boat: 1999 205v
I didnít tie mine in there as I would think that hose has vacuum and not pressure. I tied in where water heads to exhaust manifold.
Old 07-20-2018, 09:26 AM
88 PS190 88 PS190 is offline
Ya - I wouldn't install it there for 2 reasons;
1 - you may notice that any of the large through hull fittings have 2 hose clamps - this is a coast guard standard for thru hulls. You've tapped into that security and added a point of failure that will readily and fully swamp your boat if it comes apart.
2 - you want pressurized water source so tapping into an area that has pressurized flow is ideal, the line to the head is a good one.
Old 07-20-2018, 09:41 AM
Great! Thanks for the peace of mind
Old 07-20-2018, 03:56 PM
Ha well add a second hose clamp to each and try it off a bucket. Water should come out around shaft. If it isn't you'll have to reroute.
Old 07-20-2018, 04:10 PM
Incorrect location. You risk running a dry seal. Bad things will result.
John 14:6
Old 07-20-2018, 04:18 PM
Right place?
Take it out and put it in the right place.... or start a new thread in a short while with a new install..
Do it right..........or not..
.Attachment 178574
credit to Seacup
Where is the right place?
