Old 07-21-2018, 10:39 AM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Timing light
About to adjust timing on my 94 TBI with help of this thread.https://www.mastercraft.com/teamtalk...t=24783&page=4
First time user of a timing light.
What's the use of the knob graduated 0-60 gegrees advance on the light and what should i adjust it to check my 10' BTDC ?
Thanks for any help!
Keep skiing!!!
Old 07-21-2018, 11:37 AM
Base timing 10 degress btdc...
Old 07-21-2018, 11:17 PM
tommurtha tommurtha is online now
Boat: Prostar 197 2003
typically with and adjustable timing light you set the arrow to your spec, in the case 10 degrees and adjust the timing by moving the distributor do that the light on the harmonic reads at zero.
Old 07-22-2018, 10:57 AM
paco_06's Avatar
paco_06 paco_06 is offline
Boat: 1993 prostar 205 previous 85 S&S
Sounds like you have some kind of adjustable light? I wouldn't know how to tell you to use it, as there are several different kinds most engines only have 20-30 degrees of marks for adjustment. Sounds like your light can be used for greater fine tune adjustments in the event of a higher lift cam. (Racing engines)
From your description, if I understand right, set your light to zero. This will give you an actual reading. Make sure engine is warm and attach to number one plug wire. Like you and others have mentioned 10° below/before top dead center. I'm not sure if there's any special things that need to be done on a TBI engine to check timing. But I doubt it.
Sent from my XT1030 using Tapatalk
Old 07-22-2018, 04:11 PM
André's Avatar
Thanks for the answers guys!
Keep skiing!!!
