Old 06-02-2016, 03:56 PM
Boyderoo Boyderoo is offline
Boat: Mastercraft X5 2001 Predator on LPG
Fixes for Dashboard Panel Captive Nuts
I have a 2001 X5 and am currently replacing the Digital Gauges with Analogue, when pulling the Dash I had two captive nuts that had freed themselves and were spinning on the Inside, luckily I managed to get my hand up behind and got just enough grip with some long nose pliers to undo it with the wife undoing the screw end, it took about an hour to do the two nuts where the screws were just spinning the nuts , all by feel and trial and error , so any recommendations to prevent same in future?
my thoughts are;
1 Pull them out they're a liability and glue something there drill a pilot hole and use self tappers.
2 try to clean the thread on the bolt and get a tap through the nut to clean the thread
lube it up with some adhesive grease not sure if i can get a tap / die that small . or possibly wind the bolt back & forth with grease to free it up make sure it runs freely
Surround the captive nut with some kind of adhesive to secure it a bit more
3 Any other stories or what have you done ?
Thanks
Boyd
Old 06-06-2016, 07:40 PM
ddummitt ddummitt is offline
Boat: 2002 X Star, 1993 Prostar 190, Pontoon
stainless bolts from the back side. thin nut under panel to hold bolts and acorn nuts on the outside
2002 X-Star
1993 Prostar 190
Old 06-06-2016, 07:48 PM
or fill with jbweld - or marine epoxt and use black automotive screws.
Old 06-07-2016, 10:54 AM
Prostarski190's Avatar
Prostarski190 Prostarski190 is offline
Boat: 03 Prostar 197, 310 HP Predator w/ Powerslot
my thoughts are;
Thanks
Boyd
Please do a post on how you're converting digital gauges to analog.
Thanks
Old 06-07-2016, 09:04 PM
Someone posted this in another thread. May be useful. Should be able to get them at any auto parts store.
2002 X-Star
1993 Prostar 190
Old 06-09-2016, 08:44 PM
2RLAKE's Avatar
2RLAKE 2RLAKE is offline
Boat: '13 x10 with 6.0 and '93 25th Anniversary Limited Edition
I had the same think on my '93 ... I used gorilla glue and put them back in .... They work great
