Old 02-24-2011, 06:58 PM
Tommyp99
Posts: n/a
'86 Prostar transmission help
I recently bought what was supposed to be a completely rebuilt '86 Prostar. The engine runs great, but I have transmission problems. 1: I can't get the transmission into neutral and the shaft spins on start. I disconnected the cable and it will shift from fwd directly to reverse (did it twice and quit). 2: I have seen it in neutral, but the shaft still spins at about 100 RPM. 3: The fluid level is high, but would being too full cause it not to shift? Please help.
Old 02-24-2011, 11:34 PM
rjracin240's Avatar
rjracin240 rjracin240 is offline
Boat: Mastercraft ProStar 190 1988 351 Wheezer
Cannot offer any advice but sure would like to see pictures of your new boat and welcome to the Mastercraft family
Old 02-24-2011, 11:53 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
That might not be a problem...
I am thinking you have just a little bit of drag in the clutch packs is all. 100 rpm in neutral is what leads me to believe that.
Need LT-1 parts?
89058397 (pump outlet side)
Old 02-25-2011, 12:04 AM
milehigh970's Avatar
milehigh970 milehigh970 is offline
Boat: 1986 skier w/ a fresh 351 and 2008 x2 w/ MCX
i was thinking the same thing... I would get to proper level first.
Old 02-25-2011, 05:05 AM
If you have rotation with the cable disconnected and someone has just recently rebuilt the transmission then they probably didn't check the clearance on the clutch pack and used the incorrect snap ring. IE the clutch pack is to tight.
Have you ask the PO if and who did the trans work?
Old 02-25-2011, 11:19 AM
dmminfla's Avatar
dmminfla dmminfla is offline
Boat: 1997 PS 205 5.7L 275 HP TBI
The tranny is a Borg Warner Velvet drive. It's most likley that someone ran it low on fluid and warped the forward clutch plates. To fix it you will need to pull it and change the plates and set the propper gap. However if you can live with the forward "Creep" it can still work fine for some time. My 86 Skier (Prostar was not made in 86) had the same problem. Be very carful not to switch to reverse quickley because with the drag on the forward chuch plates could cause the rear plates to snap. It happened to mine.
Old 02-25-2011, 03:16 PM
I would assume the friction plates would burn up before the metal plates would warp causing slippage, not drag. Creep is normally a by product of bad clearance or a poorly adjusted cable.
Old 02-25-2011, 02:29 PM
blakehardesty's Avatar
blakehardesty blakehardesty is offline
Boat: MasterCraft Skier
Mine spins some too. I would guess way less than 100 rpm (like 20 rpm)
1984 Mastercraft Skier 1:1
Old 02-25-2011, 04:57 PM
Covi's Avatar
Covi Covi is offline
Boat: 2008, PS 197, LY6
Send a message via AIM to Covi Send a message via Skype™ to Covi
Originally Posted by Tommyp99 View Post
I recently bought what was supposed to be a completely rebuilt '86 Prostar. It's beautiful and the engine runs great, but I have transmission problems. 1: I can't get the transmission into neutral and the shaft spins on start. I disconnected the cable and it will shift from fwd directly to reverse (did it twice and quit). 2: I have seen it in neutral, but the shaft still spins at about 100 RPM. 3: The fluid level is high, but would being too full cause it not to shift? Please help.
Photos, photos, photos welcome and lets get this thing running proper!
86' 19 Skier, 351 PCM (sold)
2008 197 ProStar, LY6
Old 02-25-2011, 07:12 PM
Tommyp99
Posts: n/a
Thanks for advise, here's pictures
Thanks for all then info. The transmission is a 10-17-004 and the engine was completely rebuilt. As I look at the transmission rating, it's probably getting too much horsepower (rated at 255 and the seller said engine put about 400).
