  #91
Old 01-28-2016, 06:30 PM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Originally Posted by Mastercraftdave View Post
If you could put a seven marine engine on the back of this boat I would buy one in a heartbeat.
You can do anything with enough money.
-Mike
Old 01-29-2016, 08:11 AM
ejj ejj is offline
Boat: Not an MC
4 stroke torque?
Originally Posted by JohnE View Post
Aren't the 4 strokes abundant in out of the hole torque?
2 vs 4 strokes, who has more torque?
Doesn't matter 2 or 4 stroke, it's all in the stroke of the engine that makes torque.
Small bore and long stroke means torque, low end grunting pulling work.
Big bore and short stroke means RPMS, RPMS are a requirement to building HP. But RPMS are not a requirment for tq.
Apples to apples, 2 stroke wins every time in it's power to weight ratio, and volumeteric efficency, they flat out breath better. Where they always lose is in MPG's and emissions.
Kinda depends what the engine is designed for!
Old 01-29-2016, 09:31 AM
Mastercraftdave's Avatar
Mastercraftdave Mastercraftdave is offline
Boat: 2015 X23 SS 6.2L
You would think that is the case. When I ordered my X23 I did not really want the Surf Edition sticker on the side of the boat, however MC would not allow me get the surf edition without the sticker. I even offered to pay more for them not to put something on......
The problem with the Seven Marine Engines is the Weight. I would like to know how much weight the Transom mounts will hold because the 7Marine is about 300-400 lbs heavier.
Old 01-30-2016, 01:33 AM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
I can see a market for an outboard NXT - for those that don't want a SS inboard. I'm surprised some of the barefooters here aren't commenting.
Won't be footin' behind that... I am out.
Sanger has THE market for barefoot tournament boats. Why train behind something that is not tournament ready or approved for that matter...
Barefoot skiing is such a small niche market anyways, MC did their research and went for the better sales market.
http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
89058397 (pump outlet side)
Old 01-30-2016, 01:53 AM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
What the hell is tournament bare footing
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 01-30-2016, 03:08 AM
JLeuck64's Avatar
U R an !d!ot iF U can't Google a question!
Need LT-1 parts?
Old 01-30-2016, 10:20 AM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Originally Posted by Sodar View Post
With the right prop, an OB can pop a skier up every bit as well as a DD. Especially with the new 4-stroke OB's.
My 200 Merc 2-Stroke with its 4 blade prop will pop a skier out of the water with ease.
Mike B
Old 01-31-2016, 12:29 AM
Ski-A-Rees Ski-A-Rees is offline
Boat: Mastercraft Prostar 1989 w/ Chevy Big Block 454
Send a message via AIM to Ski-A-Rees
I understand why but I'm really disappointed they went with the four stroke. The two stroke Optimax would have been the better water ski application. Hopefully they will have that as an option when building one.
Sarasota Ski-A-Rees World Record Ten Men Around THIS BOAT!!!
Old 01-31-2016, 01:21 AM
MC25's Avatar
HA okay dude.
-Aric
Old 01-31-2016, 11:17 AM
duckguy's Avatar
duckguy duckguy is online now
Boat: 2015 X-30, 1983 Stars and Stripes, 1991 Jump Boat
Tournament Barefooting is comprised of 3 events scored by Judges riding in the boat. The 3 are:
Tricks- Just as it sounds the skier is judged on degree of difficulty and number in a given time.
Slalom-Both front and back, the number of times the skier can cross the wake in a given time.
Jump-distance jumped over a small barefoot ramp, most men go inverted or "superman style"
Also figure 8 man against man bracket elimination. The skiers typically start on a single ski and drop by the opening gates. The boat is then driven is a figure 8 pattern until 1 skier drops or falls
And finally endurance racing. Teams race typically down a river and ski as long as each skier can to accomplish a team effort of skiing a great distance as fast as possible.
