Old 05-21-2012, 07:23 PM
Brandon241 Brandon241 is offline
Boat: X2
Bunks??
Anyone replaced there bunks? Have an 05 x2 and the bunks are getting bad. Have done this on a bass boat anything different I should know? Any special carpet required? Thanks
Brandon
Old 05-21-2012, 08:24 PM
Marine carpet....saw some nice pre-made bunks at bass pro...was wondering if anyone here every used them
Old 05-21-2012, 09:11 PM
Stritt's Avatar
Stritt Stritt is offline
Boat: 2007 MasterCraft X 45 with LY6
Just replaced the carpet on Saturday. Basically the same trailer size as th x2, ours is a 205.
Ordered off eBay a 2' x 33' piece of 20 oz grey carpet. $38 delivered to our door. I crawled under the boat and removed the majority of the staples then headed to the lake, dropped the boat and completed. Took about 1 1/2 hours. The quickest way to remove the staples was to use a floor scraper I had in my tools. It would remove most of the staples then I went back with cutters and pulled the remaining.
The bunks are treated 2 x 6 x 12 using carriage bolts.
Old 05-21-2012, 10:33 PM
barefoot's Avatar
barefoot barefoot is offline
Boat: '83 Stars and Stripes
Goes without saying, but make sure you use stainless staples...
Hello, my name Ryan!
Old 05-22-2012, 08:50 AM
psychobilly's Avatar
Ultimate bunk boards dot com is where I got mine. Very satisfied with the results. I have a thread here somewhere on the install. Great product and no carpet to rot and no staples to rust or fall out. Oh and since they're plastic, no rotting of wood. My big heavy boat loads and unloads EASY and with that being said, don't unhook her until she's in the water! :-)
Old 01-14-2016, 07:32 AM
kjohnson's Avatar
kjohnson kjohnson is offline
TT Hero
Boat: 1991 Prostar 190
UBB's
I have a few small scratches that appear to have come from the ultimate bunk boards. Has this happened to you?
Love my boat, hate my trailer.
Old 02-02-2016, 07:16 PM
jovoth's Avatar
jovoth jovoth is offline
Boat: Mastercraft, X-2, 2007
When installing new bunk carpet is it recommended that you use carpet adhesive along with stainless staples??
Old 02-02-2016, 07:25 PM
Bubbacuse77's Avatar
Bubbacuse77 Bubbacuse77 is offline
Boat: Mastercraft Prostar 197, 2002
Not that I have done or seen but that doesn't mean you can't. I have never had a problem with the carpet moving or coming loose. Most of the issue I have seen is just bunk carpet getting torn or worn out from the normal wear of loading and unloading. Not sure adhesive is necessary
Old 02-03-2016, 10:48 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Treated lumber. Use the old boards to mark your holes. Replace the hardware (stainless carriage bolts presumably). Olefin marine carpet from Lowe's or Home Depot works well. Bevel the top edges of the bunks. Stainless staples. Double layer the top and sides of the bunks. Once the boat is on the bunks, go under and retighten the nuts. Speaking of nuts, either use use nylock and washers or double nuts and washers. Double nut is easier to get on without spinning the carriage bolts, but can fuse together and be a pain to get off. 6 of 1, half a dozen of the other.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-05-2016, 09:06 PM
1redTA's Avatar
1redTA 1redTA is online now
and you can anti seize the bolts to help with corrosion a little goes along way
1981 MasterCraft
19' Skier 351W PowerSlot
