Old 10-14-2018, 01:31 PM
MattsCraft's Avatar
Another Oil Change Thread
As the title states - Prob discussed 1000 times...
Specifically a 2013 Ilmor 6.2 liter V-drive
Less than 300 hours over 7 oil changes in her life - 1st, 2nd & 4th completed by the dealer.
On the 3rd, -7th including this year that I have done - I can only get 3.5 quarts out of it, regardless the method other than leaving it overnight to drain I have a mityvac, Jabsco fluid extractor (which is slower, but actually pulls about .5 qts more out! I always warm it up, this year for 20 minutes! Same result, this year, actually after sucking until it was just air, put in 2 fresh qts, & sucked that out as well, still the total is 3.5 qts including what did not drain out of the oil filter - Where the heck is the other Qt? This year I purchased a brass barbed to 3/8" fitting for the drain hose, so no air from the hose to the pump, no difference.
It put 3.5 qts back in, ran it and the dip stick shows full
I have done everything I can think of, jack the boat trailer up so it is leaning toward the drain hose, pulled it into my driveway forward, which is a slope down & left etc. always the same, 3.5 out, 3.5 back in.
So either the dip stick is off & I'm running 1 qt low, or I am leaving 1 qt of old sludge in the tank - lol
Any advise as it is always a long winter thought process of what the heck
Old 10-14-2018, 01:45 PM
moosehead's Avatar
moosehead moosehead is offline
If boat is warm and you are using the drain tube / barbed fitting / any extractor - you should be getting 5+ quarts outta her in less than 10 minutes.
Have you the removed the oil filler cap and oil filter as well?
Snowing and 22F here today. SAD!
Old 10-17-2018, 08:40 AM
93Prostar190's Avatar
Does the filter have oil in it? I believe your model has an anti drain back valve right?
Sent from my iPad using Tapatalk Pro
2008 Prostar 214 MCX
"Do you have Flake on that boat?"
Old 10-17-2018, 12:51 PM
Miss Rita's Avatar
same thing happens with my '92 PS. I attach the pump to the drain hose on the bottom of the pan, run it until it's sucking air, only get 3 quarts out. The filter probably holds 1/2 quart. I put 4 quarts in, now it's a little overfull according to the dipstick.
Old 10-17-2018, 04:24 PM
MattsCraft's Avatar
Yes - Filter off, cap open - That would be a cool trick to get 5 Qts out of a 4.5 Qt system
Rob - The filter was about 1/2 to 3/4 full by the time I got it off, this is poured into (accounted for) in my total count of 3.5 Qts.
