Old 02-17-2018, 09:56 PM
Jeffrobinson1327 Jeffrobinson1327 is offline
Boat: 2014 Mastercraft X2
5.7 Ilmor Raw Water Impeller Change How-to
I just started changing out the raw water impeller on my 2014 X2 with the 5.7L. I made a video because I could not find anything out there video-wise, and a lot of people talking about how hard it is to get at. It took about 5 minutes to get it out, never having done it before. So attached is the video.
https://youtu.be/A4UHFZHRAqU
Old 02-17-2018, 10:00 PM
hyman989's Avatar
hyman989 hyman989 is offline
Boat: 2015 Mastercraft NXT20
Nice work! I did mine the same way
Old 02-17-2018, 10:40 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
Much easier than the older x2 with the mcx. Thanks for the vid.
I once dated a girl in high shcool and her dad told me I would never amount to anything. He was right.
Old 02-20-2018, 01:24 AM
WakeWise's Avatar
WakeWise WakeWise is offline
Boat: MasterCraft X-30 2014, MasterCraft X-10 2004, Correct Craft SV211 2004, Centurian T-5 2001
Nice job. Do you happen to have the impeller part number for the raw water as well as the ballast impellers? TIA
Old 02-20-2018, 08:06 AM
2RLAKE's Avatar
2RLAKE 2RLAKE is offline
Boat: '13 x10 with 6.0 and '93 25th Anniversary Limited Edition
nice video ... can't believe you found an old impeller vane stuck in there
Old 02-20-2018, 08:32 AM
bturner2's Avatar
bturner2 bturner2 is online now
Taking it apart wasn't the challenging part for me when doing my friend's 2013. Putting it back together was less than fun. I'd like to know who was the genius that decided going with a removable keyway was a better idea than a spline shaft. Before I do my next one I'm definitely ordering a couple spare woodruff keys to have on hand. I didn't lose the original but Murphy's law would put odds that one get's dropped into the bilge a some time or another and most likely when you can least afford to not have it.
As a side note I used some silicone grease in the keyway to hold the pin in place and that seemed to work well but I really would prefer not to have that added part to deal with if I were changing the impeller out while out on the water and everything moving around.
Old 02-20-2018, 08:42 AM
CantRepeat's Avatar
Great video.
The only suggestion I would make is to not use WD-40. It will prematurely wear out the rear seal. You can achieve the same lubricating affect by using windex and bumping over the engine without starting it. Same with installing the new impeller.
Also, just a heads up, with the jabsco pumps mounted with the impellers up like they are, allow water to leak down into the motors and they will fail prematurely as well. It's a case of easy maintenance or longevity of the electric motor.
Tim
Old 02-20-2018, 09:32 AM
Mastercraftdave's Avatar
Mastercraftdave Mastercraftdave is offline
Boat: 2015 X23 SS 6.2L
Man if only the 6.2L was this easy to change the impellor. The 6.2L requires that the belt and pulley be removed to change the impellor.
Old 02-20-2018, 12:25 PM
Bwag1961's Avatar
Bwag1961 Bwag1961 is offline
Boat: 2014 Mastercraft X25 w/Gen2 and Surf Pkg.
Like the video. Well explained. Make one for winterization....I'd be interested.
Sent from my SM-G950U using Tapatalk
A boat is a hole in the water into which you pour money......but it's a lot of fun!!
Old 02-20-2018, 06:04 PM
Bwag1961, I actually don't know how to winterize yet. I have it in my 60 degree garage in WI for the winter. The dealer I bought it from did the oil/filter/etc this year. Maybe this fall I will find someone that can help and I will make a quick video.
impeller, raw water
