Old 04-30-2016, 06:49 PM
mgs96ps mgs96ps is offline
Banned
Boat: A
Single Battery Box upgrade
So my battery situation was not that great and I was in need of an upgrade. I know that there is way better battery threads on team talk.....but thought I would post a couple of pictures of my simple update.
I really wanted the battery to be concealed, have a shut-off switch, have a quick connect to charge and simple way to check voltage at any time.
Detail of work:
bought a new battery box to customize
wired in a isolator switch
wired in a toggle switch with a 10 amp fuse
wired in quick connect for charger/ maintainer
wired in a volt meter to the toggle switch. (Volt meter will also check alternator output with engine running from the on/off toggle).
Old 04-30-2016, 06:56 PM
Table Rocker's Avatar
I really like this. Job well done! It looks like I need to start buying parts to do mine.
'96 ProStar 205 SD LT-1
Old 04-30-2016, 07:04 PM
Banned
Boat: A
Thanks TableRocker. I would recommend putting the isolator switch opposite of battery posts to give yourself plenty of room for problems. Also, make your cables long enough so you have room to get top cover on and have room to tighten everything down inside box.
Old 04-30-2016, 08:27 PM
Mhlavs's Avatar
Mhlavs Mhlavs is offline
Boat: 1997 mastercraft 200vrs
Detail of work:
That's sweet you should sell them
Old 04-30-2016, 10:18 PM
So my battery situation.........
Swap out that friction grip sash connector for an old life jacket snap buckle. Makes it much easier to get on and off.
John 14:6
Old 05-01-2016, 12:01 AM
Banned
Boat: A
The hope is that I never really need to get into it....unless the battery needs to be replaced. In fact, I have the same type of strap on the inside of the box that secures the battery within the box. The outside strap secures box to floor of boat. If I ever need a jump....it will be easier to go off the starter.
I do think that I will swap out the toggle switch to something better.
Old 05-01-2016, 12:04 AM
Banned
Boat: A
I have a feeling that TableRocker is going to put together a box that going to put mine to shame. I hope he post pictures!
Old 05-01-2016, 12:34 AM
No, I won't be able to put yours to shame. Mine will be a poorly done copy of yours. I do think it is a great idea and especially like the idea of only putting holes in a battery box lid. I am inspired.
Old 05-07-2016, 09:52 PM
Banned
Boat: A
Tablerocker, tried out the new battery box setup today. Very happy with the setup and how it cleaned up my storage area. Don't know if you're still considering doing it yourself...but I think you'd be happy with it. Picture shown with battery minder hooked up....and upside down of course.
Old 05-07-2016, 11:31 PM
I like it. What are the details on the LED gauge?
