Old 06-22-2015, 12:04 PM
Shaun R's Avatar
Shaun R Shaun R is offline
Boat: 2011 X25
LT1 Prostar fuel pump part number.
Believe the Carter part number is/was P60962 but not seeing it on RockAuto or any other sites. Has the part number changed?
Old 06-22-2015, 12:30 PM
Rockman's Avatar
Rockman Rockman is offline
They may not have it...might only have the one that would work on the regular 350.
The one for the LT1 is a high pressure pump which I was only able to find places that carry it for as low as $300+.
Mike G can double check...
Old 06-22-2015, 12:42 PM
Shaun R's Avatar
Boat: 2011 X25
I was afraid of that. Don't need one now but remember it being 38bux not to long ago. Was going to pick up a spare just in case.
Old 06-22-2015, 01:23 PM
Rockman's Avatar
That was not the pump for the LT1...
Old 06-22-2015, 01:59 PM
Shaun R's Avatar
Boat: 2011 X25
Found this and it looks like it could work. Not as cheap as I thought but I may have been looking at the wrong pump.
http://www.summitracing.com/parts/crt-p5000/overview/
This one looks close but only 45PSI
http://www.summitracing.com/parts/crt-p61171/overview/
Old 06-22-2015, 02:06 PM
P60962 is the correct pump.
I have been talking to some fuel delivery designer guys... You can try this route - the extra port on the Carter P60962/P60987 is to bleed off vapor into the return line to the tank to "prevent vapor lock" I can't see this working on lt-1 since the fuel system stays pressurized. To install this you would need to cap of the fitting that is being fed by the second bottom port of fuel pump.
On my FB page someone had this done with good results. I think it would be a great solution. The carter pump is 2-stage - there's a little blade pump to spin up pressure then the gear pump feeds the system...
I personally believe this solution would work since the regulator controls pressure...
Worth a try if you can turn a wrench...IMO
Old 06-22-2015, 02:17 PM
Shaun R's Avatar
Boat: 2011 X25
P60962 does not show to be in stock or available anymore. Wonder if it was discontinued? Don’t mind going the other route if needed.
Old 06-22-2015, 03:37 PM
P60962 is available here... www.skidim.com http://www.skidim.com/prodinfo.asp?number=55-6014 http://www.bakesonline.com/detail.aspx?ID=1241
look for part 556014
Old 06-24-2015, 11:59 AM
Chrismaristar Chrismaristar is offline
Boat: 1996 Mastercraft Maristar
Here is 1 more, he has 15 on hand ..sale price $264.00
http://store.inboardonline.com/iwwid...%201&source=sc
Old 07-26-2015, 06:05 PM
lee1551 lee1551 is offline
Boat: MasterCraft, ProStar, 1996, Indmar LT1
MikeG, I'd like to try using a pump without the extra "vapor return line", like this Carter P61171 http://www.summitracing.com/parts/crt-p61171
Can you point me to the Facebook page you referenced? I'd love to replace my bad fuel pump with a $60 one rather than a $300 one.
By the way, I've never posted on here, but we've used your threads to diagnose and fix just about every issue we've ever had.
