Old 05-30-2017, 04:18 PM
96 LT1 Prostar 96 LT1 Prostar is offline
Boat: 1996 Prostar 205 LT1
Throttle Spring 96 LT1
I have a 1996 Prostar 205 LT1, after pulling a rider or running at higher RPM after shifting to neutral the engine will rev to about 1500-2000 rpms. After looking closely it seems that the "throttle return spring" is weak. I have it rigged with a small bungee cord and slight tension to get me by for the weekend and it seems to work but still a little rough at shifting. It brings the throttle back to the stop point which is the idle. Can't find a replacement spring any where. Any thoughts or suggestions?
Thanks
T
Old 05-30-2017, 05:55 PM
Boat: 93 190
Thanks
T
Holley, Jeg's Summit Racing, any speed shop or Amazon.
John 3:16-18
Old 05-30-2017, 06:00 PM
Table Rocker's Avatar
Since the boat throttle is returning too well, wouldn't the throttle return spring be too strong? There are cable clamps available that put more friction on the throttle cable.
'96 ProStar 205 SD LT-1
Old 05-30-2017, 07:54 PM
Well it returns fine out of throttle but when there is no load.. like in neutral- the engine revs. You can simple lift the hood and set it back to the idle position.
Old 05-30-2017, 07:57 PM
I apologize, I answered the question I thought you were asking without reading carefully. My throttle tends to creep towards lower RPMs when my hand isn't on it.
Old 05-30-2017, 09:33 PM
Here are some pics of the spring needed... you can see the little plastic tab sticking out doesnt even rest up against the linkage bar.
Old 05-30-2017, 09:53 PM
have you tried it without throttle cable? could be a sticky throttle cable.
Old 05-30-2017, 11:42 PM
mgs96ps mgs96ps is offline
Boat: A
Attached is the only picture I have in my phone on how mine seats. I think you just need to wind the spring another rotation before inserting into plastic tab.
