  #7211
Old 05-05-2018, 06:30 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
Cleaned her up. Should Be ready for the water next weekend
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 05-05-2018, 09:07 PM
Black n Green's Avatar
Black n Green Black n Green is offline
Boat: 2017 XT21 6000GDI
100 hour oil change
First time using a pump through the dipstick tube. Why have I not used one of these before now? Made the job easy and zero mess.
Oil flows through the tube so much easier when it is warm. Used 4 hours of surfing to prep the oil before extraction.
Old 05-06-2018, 08:37 PM
lakedrum03's Avatar
303 fabric guard on the cover.
Old 05-08-2018, 07:45 AM
dbismyname dbismyname is offline
Boat: 1999 205v
Pulled her out of hibernation. Reattached hoses, reinstalled block plugs, put in new impeller. Fired up on fake a lake and ran for 15 mins. Batteries had not even been disconnected or tended since Sept, fired up first turn. Drained oil after running and realized my filter wrench isnt at home and my grease gun doesnt work. So today will be greasing rudder box and finishing oil change. Also gave her a bath and hooked up battery tender. Missing any other spring must dos?
Old 05-08-2018, 07:53 AM
MattsCraft's Avatar
Added some MCOCD Cleats in my rear lockers for ropes & fenders. I had 4 I bought off of Alberta Surfer a couple years back, had no idea what I was going to use them for, I think this will work out nicely!
I did change my tranny fluid (244 hours) - Yes I went with RedLine Type R per the ZF recommendation in that other debate thread on tranny fluid - I could only get a little over 2.5 Qts out, so that is exactly what I put back in - yes I cleaned the metal filter
Old 05-09-2018, 05:57 AM
bret's Avatar
bret bret is offline
Installed my two lifts on B Dock so now, MC and Sea Doo will be in a double on same dock. Some other ski club members on same dock and one dock over on A Dock. Helps to keep an eye on things.
Old 05-19-2018, 07:20 AM
mike koen's Avatar
mike koen mike koen is offline
Boat: mastercraft x-14 2008 mcx
New cover , replaced swim platform pad and replumb kit done
If she don't shine , she ain't mine
Old 05-19-2018, 07:23 AM
mike koen's Avatar
Upgrade
Old 05-19-2018, 06:51 PM
Slinkyredfoot's Avatar
Slinkyredfoot Slinkyredfoot is offline
Boat: 1979 Mastercraft, 1998 ProStar 205
Started right up after being in storage for 5 plus months. Suds are from lube in impeller works
All the time.
If for some reason you start to believe you are a person with influence, just try ordering somebody else's dog around.
Old 05-29-2018, 12:49 PM
ccelia's Avatar
ccelia ccelia is offline
Boat: 2009 Mastercraft X-45
With rain in the forecast for MDW, I spent the weekend cutting holes in the boat to install another set of JL M770s and a second JL M10IB5 subwoofer. This is the first time I have cut holes in the boat, so it was a little nerve-racking, but I used a dremel with a multi-purpose rotozip bit and the circular cutting attachment and it worked perfectly. The dremel was a slow process (probably 5 minutes per hole), but I felt confident knowing that I was getting a perfect circle. There were a few electronics under the helm that had to be moved, but other than that, it was a straight-forward install.
I am still in the process of wiring up the new MHD amps, but I can't wait to hear the well rounded sound in the cabin.
