Old 07-29-2010, 11:58 AM
dstone124's Avatar
dstone124 dstone124 is offline
Boat: '06 X7
Zero Off
I'm sure this will be beating a dead horse, but I've emailed ZO and as of yet, no response. My hope is with the wealth of knowledge that's on this forum, somebody out there can give me a clue.
My '06 X-7 with the 310hp RTP is of course DBW. I currently only have the MasterCraft standard cruise control and would like to upgrade. Being that I am a entry level tournament skier, I would like to train behind the system required by USA Waterski. I know my boat is compatible with StarGazer, and I have a line to purchase that system. Question is, is my DBW system running the ECU that ZO requires, if not, is it possible to make this change?
I know there are engineers out there that are converting earlier model boats to run ZO but its big money and lacking results.
Anybody gone thru this already?
Thanks in advance for all the insight.
-dstone
Old 07-29-2010, 12:06 PM
Esiegert's Avatar
Esiegert Esiegert is offline
Boat: MasterCraft, 1990 Prostar Ford 351
Dstone,
your current boat is not running the Ecm required to run Zero Off, you would need an e-control ECM. I have see a couple of cases where ZO & E controls have built an ecm that will replace your current one, but it is not a cheap!
Hope that helps...
Bennett's Boat & Ski
Bennett's wakeboard & waterski school
1.800.869.7297
225.654.9306
Old 07-29-2010, 04:02 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
If your are an entry level skier, you won't be able to tell the difference between the two speed control systems on the end of the rope. In the driver's seat, ZO will be a little more user friendly. But unless you're planning to enter tournaments, I don't see much reason to spend the money it will cost to modify your boat for ZO. SG is an extremely good system and will be an easy install on your boat.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 05-15-2011, 08:54 AM
rawly rawly is offline
Boat: 2005 Mastercraft X-7
I have an 05 X-7 MCX with drive by wire.Any updates on the Zero Off conversion?My ECM needs replacing(boat sank),and I'd really like to get one that will run Zero Off and Perfect Pass.
Old 05-15-2011, 10:49 AM
MC Hero
Check with Jody at FL inboards. He will know the answers. He has been convertting a lot of boats in the last few years.
FAQ
Be kind. Have fun.
Old 05-15-2011, 12:51 PM
Sullivan's Avatar
Sullivan Sullivan is offline
Boat: 2011 WTT ProStar 197
Why? I had Zero Off and Perfect Pass on my 08 Response Lxi. We never used the Perfect Pass once we had Zero Off.
I ski behind several boats and I have a hard time telling a difference between the systems when PP is set up correctly. Go with PP and don't look back.
Old 05-15-2011, 04:42 PM
Thanks east tx,I'll get ahold of him.The reason I want to be able to run both is that I have perfect pass,but may switch to zero off in the future,so if I have to get a new ECM,I'd rather get one that will run them both.
Old 05-15-2011, 10:31 PM
macattack's Avatar
macattack macattack is offline
Boat: 2005 MasterCraft PS197 TT, #31/100, MCX 5.7L
I believe your '05 will require more than an upgraded ECM to make it ZO compatible; as Eastie mentioned, Jody will be able to answer that one. Additionally, don't forget PP is working on a ZO simulator upgrade to their PP/Star Gazer system that will hopefully be ready at the end of this month/May...mac
http://perfectpass.com/perfect_pass_whats_new.html
2005 ProStar 197TT, #31/100; Tournament PB 1.5 @ 38 off, June 2012
Old 05-15-2011, 11:39 PM
nmcjr's Avatar
nmcjr nmcjr is offline
Boat: 2002 X-Star
Edit: duplicate of above about zo mode....
2002 X-Star
http://www.nopowerturns.com
Old 05-16-2011, 05:05 PM
Thanks Guys,
I spoke with Jody and he said it's not an easy conversion or a cheap one.Best bet is to go with the newer Perfect Pass when it is available as you guys stated.
conversion, zero off
