Old 07-02-2018, 11:42 PM
Mangler's Avatar
Mangler Mangler is offline
Boat: 2008 X-15 SS w/MCX
Heater & horn not working (X-15)
Other functions on the left panel are working fine. Boat is a 2008 X-15.
I checked the circuit breaker things right by the battery switch and by the driver’s right foot.
Are there more breakers or fuses somewhere?
Thanks!
Old 07-02-2018, 11:45 PM
Canwan Canwan is online now
Boat: 2008 MC X2 MCX
Try looking to see if the wires pulled off the switches. This happened on my x2. The wiring is very neat but very tight.
Old 07-02-2018, 11:48 PM
Mangler's Avatar
Did you take the whole switch plate off to check, or...?
Old 07-02-2018, 11:49 PM
I am pretty sure you can see them by lying under the dash.
Old 07-03-2018, 10:41 AM
Mangler's Avatar
Thanks; I’ll look tonight.
Old 07-05-2018, 02:21 AM
Mangler's Avatar
That wasn’t it.
Unfortunately, I broke the heater switch unplugging and replugging the wires too...
I looked behind the carpet panel from the bow seat looking back at the dash too—I wouldn’t even know where to start in that mess of wires. I did see a couple things labeled, but no heater or horn.
Happy 4th!
Old 07-05-2018, 09:19 AM
Does the heater switch light up when you turn it on? You probably don't have the seat heater you can probably swap switches.
Old 07-05-2018, 09:42 AM
Mangler's Avatar
I actually do have the seat heater and it works. Plus, it is a 2-way switch.
The heater is a 3-way switch with about 5 wires on the back iirc. It was NOT lighting up. The bottom right terminal didn’t have a wire on it (when I looked from the back), but there was an extra spade connector coming from another wire (I think the 9 o’clock position). I hooked that one up to the empty terminal at the 5 o’clock position, but and the light came on; but, the heater switch was in the center OFF position. When I was pulling that wire off, the back of the switch popped off. I tried to put it back together, but now it doesn’t flip properly.
No change at all on the horn...
I’ll probably just have MC look at it when I take it in at the end of the season.
Thanks though!
