Old 05-14-2017, 10:48 PM
Scottb Scottb is offline
Boat: 2002 Mastercraft x5
Changing oil
First time Mastercraft owner, looking to change oil in 2002 X5 I purchased. I can't find any diagrams online I guess due to proprietary information, but I did manage to find the oil filter and what I thought was the drain(first pic). Pulled what I thought was drain and nothing but water came out..I also found a tube at the bottom (next pic) which I am now thinking is the oil drain, can you tell me if I am right and what I accidentally drained? Thanks.
Old 05-14-2017, 10:56 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
Tube out of the bottom is the drain.
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 05-14-2017, 11:01 PM
j2shay's Avatar
j2shay j2shay is offline
Boat: 2000 prostar 190 330 ltr
Smile
If I am looking at it right you pulled one of your plugs to drain the block of water for winterization and such on the first pic. The tube with the brass plug on the end is the oil drain for mine and should be for yours. Don't quote me I would hate to be responsible if it is not but I would have a hard time thinking that it wouldn't be. Just for reference my boat is a 2000 prostar 190 with a 330 ltr engine. Fyi tighten back down the engine block drain plug if you haven't and give your bilge a cleaning while you are at it.
Joel
Old 05-14-2017, 11:20 PM
Mastar Mastar is offline
Boat: 2009 Mastercraft X Star
Just fyi that drain hose in the pic will go out your hull drain. I run the engine for 10 to 15 to get warm then use an oil pump to speed up the process.
Old 05-14-2017, 11:53 PM
CheeseSteak1's Avatar
CheeseSteak1 CheeseSteak1 is offline
Boat: 2009 X30 MCX / 2003 X2 MCX
Oil pump all the way!! Get a fitting to thread onto that hose and pump the oil out. 1. it will take 5 minutes to change your oil vs hours waiting for gravity 2. less mess pumping directly into a container 3. You can change it on the water if needed. Some guys on here have some pretty fancy pumps. Here are a few options below. BTW, do not stick the tube down the dip stick and extract the oil. Many members have been on here asking for help due to the tube getting stuck. Buy the correct fitting and secure it to the tube. There should be several threads on here with pics. Hope this helps.
https://www.amazon.com/Koehler-Enter...extractor+pump
https://www.amazon.com/Mityvac-7201-...extractor+pump
https://www.westmarine.com/buy/west-...cket--14557425
make your own with a 5 gallon buck and this pump
https://www.amazon.com/YaeTek-Excell...s=12v+oil+pump
Old 05-15-2017, 09:46 AM
epnault's Avatar
epnault epnault is offline
Boat: 2016 ProStar 6.2L
Definitely use an extractor pump. So much easier and less messy
Old 05-15-2017, 03:27 PM
TallSkinnyGuy TallSkinnyGuy is offline
Boat: 1997 Prostar 190
If the engine is warmed up the oil should completely drain out of the drain hose in under 10 minutes. Well, that's what mine does, anyway.
Old 05-15-2017, 03:31 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
That ^^^^
Or do like I do on my 197 and run that hose out the drain plug hole and drain it out that way. It can take awhile and be a slow drain.
Old 05-15-2017, 04:45 PM
pondo pondo is offline
Boat: 2005 Mastercraft X-2
I bought this oil extractor from harbor freight and works perfectly (also useful for anything that needs an oil change): https://www.harborfreight.com/6-1-4-...tor-46149.html
I made a brass adapter fitting that connects directly to the hose from the oil pan. When the oil is warmed up, it'll only take 2 minutes to drain the entire pan. You can also use it to change your tranny fluid too.
Old 05-16-2017, 09:04 AM
Keith2230's Avatar
Keith2230 Keith2230 is offline
Boat: 2006 X-30 MCX
Like previously mentioned the hose with the brass plug on the end is the oil drain. The idea is you can run it out the rear drain plug so you won't be spilling any inside your boat. I too prefer pumping it out. It's quick and I can do it with my boat in the slip.
oil change
