Old 07-08-2013, 09:01 PM
fryguy17601 fryguy17601 is offline
Boat: Mastercraft x2 2010
X2 wake help pictures?
Not sure if it is a boat set up or wrong rider but want help to get my son surfing ropeless. I am not able to get pictures to load on the site so I am posting what I put on Wake World sorry. http://www.wakeworld.com/forum/showthread.php?t=798998
Thanks in advance for help!
Andy
Old 07-08-2013, 09:53 PM
VP46's Avatar
VP46 VP46 is offline
I tend to stand closer to the edge of the board but not sure if that helps me at all....
What I do know for a fact does help is the super man tactic.... this is where when you know you are slow on the wave you put your arms out like super man to speed up.
The problem with my boat (205 hull) is the weet spot is VERY small - more weight would help.
More weight in the rear lockers make the wake taller.
More weight up front make the longer.
I noticed the biggest difference when I added weight up front.
if I had my druthers I would replace the hard tanks with 750s and get a 500lb triangle up front and maybe a side sack too. (I would then drive very very very carefully )
Old 07-08-2013, 10:31 PM
Mossyrocks Mossyrocks is offline
Boat: 2014 X46 6.2l
What they said and the trim tab should be up.
Old 07-08-2013, 11:03 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
There are a few things you can do:
1. Slightly turn the boat. A 5 or 10 degree turn inward. Try outward as well.
2. Have him move his back foot and front foot forward an inch or two, maybe three for the back foot. Get his toes closer to the edge of the board. Use the wave to lift the board up, then slide down. Once he finds the pocket, ask him to try to define it by measuring the areas where the rope has slack.
3. Speed... Try going .5 mph slower, or .5 mph faster. Try going 1 mph faster/slower. Make fine adjustments after that.
4. Adjust the rope length. Shorter or longer, he could be missing the pocket.
5. If you can find a bit bigger board it might help. I have a cwb ride that everyone can go rope less. My inland surfer, mucus, is a bit faster and a little more tricky but man I love it. I doubt the board is the problem. Just one thought. Edit: that inland surfer red rocket should work great.
6. Add more weight in the corner and on the bench side of the boat. More people or buy a couple of 400# sacs. Not sure where ur at, but I'd borrow one first to try it out.
Old 07-08-2013, 11:14 PM
jgraham37128
Posts: n/a
I have a 2010 x2 and surf. I fill the port side full and the KGB full. the starboard s at 0. No plate down, this raises the back of the boat up which will make the wake smaller. I also have a 500lb sack in the rear port I use. We surf at 9.5-10.2 mph. If you have three people in the boat move them back to the left rear side and this will be the same as the fat sack. Your son looks to have to much weight on his rear leg. From font is gas and rear is for brake.
Old 07-08-2013, 11:22 PM
Boat: 2014 X46 6.2l
Also one thing a lot of people overlook is the water depth. Our wake flattens and washes out around <10'. <7' and its gone.
Lot of good ideas here, cant think of anymore.
Old 07-08-2013, 11:59 PM
Boat: 2012 X30, 6L
Yes, I see a difference at 10ft again at 15ft and finally, anything deeper than 20ft seems to be the best. Minimum should be 12-14ft.
Old 07-09-2013, 12:01 AM
BrooksfamX2's Avatar
Boat: 2007 X2
When I was learning it helped to have my toes closer to the inside of the board (closer to wake) and bend at the waist a little to get weight on the toe side edge helping to drive into the wake. By the looks of the picture, he is leaning back pulling on the rope. it may take an hour or two to find the sweet spot and be able to go ropeless for any length of time. I surfed behind stock 2007 X2's before adding a bag to the surf side..........
Keep at it, you'll get it.
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
Old 07-09-2013, 10:29 PM
scottsx2's Avatar
scottsx2 scottsx2 is offline
Boat: X20
What are the weights of the bags you are using?
Old 07-09-2013, 11:14 PM
Boat: 2007 X2
My single surf side (port side) bag is 455lbs.
My best wake settings: (medium sized wake)
Starboard side 1/4-1/2 full
KGB full
Port side full
Bag full
Plate down 1/4 to lengthen pocket a bit (still not long)
9.8 mph
Very surfable wake but not huge.....
