Old 07-26-2016, 10:53 PM
197 TT's Avatar
197 TT 197 TT is offline
Boat: 2016 X2 and 1985 SS (Sold - 2008 X2, 2003 197 TT, 1993 205)
'16 X2 Ballast Bags overflow elbows hit the rear compartment brackets?
See pics, purchased a new X2 and the piggy back sack vent elbows are directly aligned with the rear locker brackets/gas shock. They fill out the compartments perfectly so it is hard to re-position them much in any direction. As you can see I kinda rolled them to the out sides of the boat which helps but then the don't purge the air out or fill completely. Twice one side completely ripped the threaded connection out of the sac. Anyone had this issue? Any suggestions?
2016 X2 - Current
1985 SS - Current
2008 X2 - Sold
2003 197 TT - Sold
1993 205 - Sold
Old 07-26-2016, 11:58 PM
ap77's Avatar
ap77 ap77 is offline
Boat: 2015 MasterCraft X-20
You should be able to adjust the position of the bag (when empty) so it will fill in a different position. Try to reposition the bottom of the ballast bag (focus on the corners and edges).
- Andrew
2015 MasterCraft X-20 (current)
2009 MasterCraft X-2 (sold)
Old 07-27-2016, 09:59 AM
2016 x2's Avatar
2016 x2 2016 x2 is offline
Boat: Mastercraft, X2, 2016
Mine is the same. I have bags positioned so overflow is in center. Took 1 minute off of timer so not pushing on strut. If we want them completely full I finish them off manually.
Old 08-14-2016, 09:37 AM
SS LS1's Avatar
SS LS1 SS LS1 is offline
Boat: '13 X2 Pro Gen2, '98 30th Anniv PS190- SOLD-
Bump, Currious if there are any other solutions? (Rotatebags and notch the underside of the top deck for example )
These are the standard Gen2 additional bags correct? How much weight is each rear bag adding to the boat? Thanks.
Old 08-14-2016, 01:42 PM
197 TT's Avatar
I had the standard Gen2 which were 350 lbs, but ended up putting 450 sumos in, the overflow ports are offset and alleviated the issue and I can also get another 30-60secs of fill with these.
Dealer did call Mastercraft for me and their recommendation was same as above, take a minute off, i would have done that but randomly found these sacs in the classifieds on here and they work great
https://www.wakemakers.com/launch-pa...-jr-v-450.html
2016 X2 - Current
1985 SS - Current
2008 X2 - Sold
2003 197 TT - Sold
1993 205 - Sold
Old 09-17-2016, 08:55 AM
SS LS1's Avatar
Bump for old thread.............. Great information! Is there any way you could post a photo of your bags filled on each side? I would love to do this over the winter. Where did you locate your vent fitting?
Do your new bags fill completely? Mine vent from the front and seem to trap a lot of air in the center so I'm not getting full ballast weight. However they do not come in contact with the lid shock mount. Maybe they have been switched already? Do these look like stock (Gen2 retrofit) bags?
I was thinking of turning the bags around venting from the back to see if it fills completely. Any suggestions?
2013 X2 Pro Pkg, Gen2 Surf
SOLD - 1998 30th Anniversary ProStar 190
