Old 12-21-2013, 09:55 AM
Trent 197's Avatar
Trent 197 Trent 197 is offline
Boat: 2011 X2
Question about engine drain plug
Guys,
When I had my 197, I drained the block all the time in the winter. It had just had a plug fitting on each side of the block, that's it. When I went to drain the block on my X2 for the first time, I noticed that it had a wire going to the fitting. I didn't drain it because I didn't know if there was anything special I needed to know.
See photo below. Is this the engine thermocouple? If so, anything I need to know before I remove and drain the block? Is it as simple as unthreading and removing the t/c (if that's what it is) and letting it drain thru the threaded reducer bushing (or for better flow, remove bushign too)?
Thanks!
ps. if this is the t/c, where was the engine temp measured in my 197?
Old 12-21-2013, 09:58 AM
jgraham37128
Guest
Posts: n/a
that is the knock sensor but you need to drain it too. Just be careful when loosening and tightening it back up.
There are many post on this.
Old 12-21-2013, 10:02 AM
Trent 197's Avatar
Boat: 2011 X2
Oh, OK, thanks!....let me search for them.
Old 12-21-2013, 10:14 AM
Trent 197's Avatar
Boat: 2011 X2
I couldn't really find any post explaining how to "be careful" in removing the knock sensor. Is it that fragile? I'm assuming you just remove the top nut, pull the sensor and then drain the engine.
Also, the raw water pump outlet is hard piped. How to drain?
Thanks!
Old 12-21-2013, 10:59 AM
BG1772's Avatar
BG1772 BG1772 is offline
Boat: X-Star, 2001 5.7L LTR
I've destroyed several knock sensors when removing them to winterize. The knock on your boat looks like a much better design in that it has good spot to put the wrench. As for being careful, you don't want to over tighten when reinstalling. I think you only want to tighten to about 14 foot pounds.
Sent from my Galaxy Nexus using Tapatalk
2001 X-Star 5.7l LTR
Old 12-21-2013, 12:10 PM
A little anti-seize will give your block and knock sensor a long life... BG1772 is right very little torque... no pressure....
Old 12-21-2013, 03:09 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Unplug the wiring harness and remove completely from the block.
Old 12-21-2013, 08:41 PM
dsword dsword is offline
I just did this on our 2006 Xstar. Remove the nylock nut and slide the knock sensor off of the block plug. Use a one-inch deep socket to remove the plug. This will make sure your knock sensor is not damaged.
David Sword
Old 12-21-2013, 10:08 PM
Thanks!
Finger tight, then another 3/4 turn is all it needs. There's no top nut, just a plastic plug on a blue wire on the older ones.
Old 12-21-2013, 10:43 PM
CantRepeat's Avatar
Boat: No Boat
Yo big money grip!!!
Smash that stuff wit a hammer!
Tim
