help problem with XSTAR 2013 P ballast & display ?
hi all,
got a little problem with one of the ballast or the display on my Xstar 2013 when i hit the "fill all" button the "P ballast display" shows in less than 2 sec a 100% filled while the 2 other ballast are still filling at a quite normal speed. then the wake on the "Left" (if you are riding benhid the boat) is not well formed. foamy no matter what speed. tried to use the "over fill" button for that ballast but doesn't seem to fix it. Not sure if the two are related.. ![]() Last edited by M3lelena; 12-16-2013 at 03:42 PM. |
Sounds like the Port tank timer is off, what time is it set to. Should be the same time to fill as the Starboard. Or, if this is not the case, try to shut off the battery switch for a few moments turn back on to reset the system.
where can i check what time it is set to? ![]() |
In your ballast settings screen.
Send me a PM with your email and I can send you the Murphy manual. |
you got PM
If You Find Too Many Capitals You Can Keep Them...I'm German ![]() It's always 5pm somewhere, time for a beer! |
fill time on the P ballast appeared to be low..anybody knows the correct value for each ballast?
Thread Tools | |
Display Modes | |
